Vätte
1
100%
Ääniä yhteensä: 1
Vätte
[size=2.65em]Vätte
[/size]
Vätte - Nordic Champion 2016
Vätte - European Champion 2015
Technical stuff:
Chassis: DravTech SuDu Zero
Axles: DravTech Mini axles
Links: Lower links DravTech TI, uppers DravTech AL/CF
Transmission: Team Losi Mini Crawler
ESC: Tekin B1R
Motor: Extreme 380X heli motor
Servo: Protek 160T
Battery: Turningy Nano-Tech 2S 300mAh 45-90C LiPo
Radios: Sanwa/Airtronics MT-4
Tires: Purpmart 4.25" Mini Voodoos
Rims: DravTech 1.9
Shocks: Axial SCX10 Aluminium (shortened)
Springs: Team Losi Mini-T (Pink in front and Red in the rear)
Drive Shafts: SDI Propeller Shafts (Shortened)
Skins: Krawler Konceptz
Else: Over- and underdrive in axles. CF Motor plate in transmission. Aluminium gears in transmission. RCBros spring cups.
Sijoituksia:
2017:
Nordics (Nordic Championships) Vantaa, Suomi: 1
2016:
RC Crawler Worlds (World Championships) La Couronne, Ranska: 2
Nordics (Nordic Championships) Tanum Strand, Ruotsi: 1
Finnish RC Crawling Series #1, Lappeenranta: 1
2015:
EuroCrawl (European Championships) Almuñécar, Espanja: 1
Kisoja takana: 5
#1: 4
#2: 1
Viimeksi muokannut Zarizi Tech, Pe 19.06.2015 21:36. Yhteensä muokattu 2 kertaa.
28x Finnish Champion
Vs: Vätte
Dravpnir;5298465 kirjoitti:A thread with few pictures is a boring thread, so lets fix that a little bit... Kuva
My plan was to keep my last pair of the stainless spools for a project, but hey what don't you do for your team drivers Kuva Kuva
Exceed 1/16 ring gears on the DravTech stainless spools for both the front and rear.
For the front there is a Exceed 1/16 pinion gear on a modified Losi pinion shaft. I have grinded down the flange on the shaft. The Exceed shaft is a little bit bigger than the Losi one so I added a drop of Loctite 648 so it will not have any play.
For the rear there will be a modified Axial gear giving it some underdrive.
The transmission contain the HR aluminum gears. To avoid that the output shafts beats up the pocket in the aluminum gear I have added some Loctite 648 so now those shafts are going nowhere.
The transmission housing also got one of the DravTech CF motor plate prototypes. The function is good, but I am not happy how it lines up with the housing yet. I have to send Samu a proper one when I have them ready Kuva
As I hate M2 thread in plastic I had to mount some aluminum inserts in the bottom holes of the transmission housing.
Transmission mounted on the SuDuZero skid.
Just a skid is boring so lets add a chassis around it Kuva
Then I had time to assemble the knuckles.
Then time ran out for today, but this is up next Kuva
Viimeksi muokannut Zarizi Tech, Pe 18.09.2015 10:00. Yhteensä muokattu 1 kertaa.
Vs: Vätte
I have received the first parts for this project for me!
COOOOOOOOL skins by Krawler Konceptz. Kuva And these must needed tires from PURPMART! Thank you guys. Now I'm just crossing my fingers, that Tobias can make the rig complete it time. Kuva Cause training is only for the weak! Kuva
Viimeksi muokannut Zarizi Tech, Ma 26.10.2015 16:02. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Dravpnir kirjoitti: A little more done. Axles are coming together and next up is shimming the ring and pinion gear so I can start shortening the axles.
The wheels are also assembled to be ready when the tires are done.
Viimeksi muokannut Zarizi Tech, Ma 26.10.2015 16:03. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Received batteries today! Kuva
HK Nano-Tech 300mAh 2S 45-90C
Jeeeez, these are small. Kuva
Viimeksi muokannut Zarizi Tech, Ke 04.11.2015 17:39. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Dravpnir;5330810 kirjoitti:Time for some progress report Kuva
Finished up the upper and lower links
Then it was time to mount the motor which is then now discontinued Xtreme 380X motor. I also used a DravTech mini motor CF spacer.
The pinion is 14T and the spur is 60T. That combo with 2S works great on this motor, imho.
Nice and tight between the pinion and the chassis Kuva
Then it was time to focus on the electronics. The esc will be a Tekin B1R and then a Sanwa RX371 receiver.
After removing a bunch of "crap" from them I mounted them in the chassis. On my own mini I have them on top and behind the servo, but I like this placement more so I will rearrange my electronics like this.
The battery connector will be a normal JST one. After taking the picture I forgot that I have to add some cables from the battery to power the servo... so I need to redo the connector.
Viimeksi muokannut Zarizi Tech, Pe 13.11.2015 10:00. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Dravpnir;5333938 kirjoitti:More progress! Servo bypass made and when I was at it I also added the capacitor to the esc. I do not use it on my mini, but Samu is tougher on his rig than myself so perhaps it is for the best... Kuva
I also wasn't totally happy how the rx placement turned out but I couldn't set my finger on why... today I figured it out... It needed angled pins of course!
ahhh... much better Kuva
I also skipped soldering back the pins that aint needed. Saved perhaps 0.1 gram or so.. Kuva
Lot less stuff hanging down this way
Capacitor in place
New JST connector and the servo bypass adapter in place ready for the front axle.
Then it was time to shorten some shocks. Axial Aluminum SCX10 shocks with machined pistons, mini-T springs and RC Bros spring cups.
Except skins (which are on it's way) the chassis is now finished. Time to move on to the axles next time.
Viimeksi muokannut Zarizi Tech, To 19.11.2015 16:57. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Dravpnir;5333938 kirjoitti:Work, work, work... Kuva
This is such a beautiful sight
Finished rear axle
Mounted to the chassis
A slow start on the front axle
Viimeksi muokannut Zarizi Tech, To 19.11.2015 16:58. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Dravpnir;5333938 kirjoitti:Time for more progress Kuva
Made some brass weights for the holes in the knuckles so Samu can use the maximum weight of the knuckles if he wants.
Heavy little knuckles...
With the knuckles done and the driveshafts cut and grinded the front axle was done.
The it was time to glue the tires to the wheels. 4.25" Voodoo's and a combination of 1.9" Rover foams as inners and CI 4.25" Lill'Nova outer foams as outers (soft front, medium rear).
Time to put stuff together!
S.D.I 4x4 propeller drive shafts shorted and mounted.
Now it is more or less done so time for the KK skins Kuva
Now it it only time to program the esc, add some thread lock to the set screws in the drive shafts and then test drive it Kuva
Samu, soon it will be in your hands Kuva
Viimeksi muokannut Zarizi Tech, Pe 20.11.2015 11:21. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Zarizi Tech;5247929 kirjoitti:Vätte
Technical stuff:
ESC: Tekin B1R
Servo: Protek 160T
Rims: DravTech 1.9
Updated the first message. Kuva
First of all a BIG THANKS to Tobias for building me this rig. It has been fun trip to follow all the updates and quality photos you have put here. Kuva It so much easier to build a rig without actually doing anything! Kuva
Fantastic work. If it drives as well as yours in the Nordics, I sure am happy guy! Kuva Can't wait to run few batteries with it in Spain. For the comp my motivation is to fight for the big one. With this rig it sure is in the reach. I just have to get "the feeling" for it. Kuva
See you soon guys! I'll leave tonight to the warm beach of Almuñécar! Kuva
Viimeksi muokannut Zarizi Tech, La 21.11.2015 11:03. Yhteensä muokattu 1 kertaa.
Vs: Vätte
First comp behind with this rig! Kuva
I got the rig on thursday night. Last day before the competition. After "few" mojitos in the beach bar I went to get it from Tobias. Really cool rig!! Kuva Quickly did the setup for MT-4 and head for the rocks at 2AM in the night just to find out that the french and italian guys are there doing some training with headlights! Kuva Got some serious spotting from Cirederf to get my lines correctly. Kuva This training session will be remembered for a long time. KuvaKuva
Few hours after that we got up and made the courses for 1.9. What a weather! Kuva
So, to this point I had one battery of training. Oh well, that should be enough. Kuva
I have to admit, it looks so darn cool! Kuva
Checking out the lines with my nr. 1 rival of the day, David. Kuva
First course on the way!
Had to take a tactical reverse. Bummer... Kuva
Little bit more challenging course two here.
Rig was working just like the one I loaned from Tobias in the Nordics, if not even better. Kuva
So easy and predictable to drive. Kuva
First reverse to this bonus didn't go as planned. You'll see that from video soon. Kuva
Drove eleven of twelve bonuses of this day.
This brand new rig really was shining under Spanish sky. Kuva
Another tactical reverse to clear gate ten.
Course four looked really tricky before we got to drive it.
Rig was working even better on some spots that I had imagined. I could switch the line as I drove and the confidence to the rig was rising gate by gate. Kuva
This was definately one of the coolest gates of the comp.
No problem for SuDu Zero.
Rig felt suprisingly stable on downhill as well.
I just have to give props for David, who cleared this bonus without any problems. Really nicely done buddy!! Kuva
The most challenging course of the day. Team Ottsix course 5.
Managed to drive without mistakes right until the last bonus.
Spring setup seemed to be spot on for this comp.
Here is the hard bonus. It was steeper than it looks to be.
All of this wouldn't be possible without DravTech! Thanks Tobias again! Kuva
On the way to last course.
Till this point I was already quite confident about the performance. Kuva
Nothing would stop Vätte being number one! Kuva
Going for the fierce downhill bonus.
Here you can see. It doesn't lift the rear even at this angle. Kuva
Time for.....
...video corner!! Kuva
Krawler Konceptz Course - (-38/-40)
https://www.youtube.com/watch?v=4_lKgBZYbEw
I had no bigger problems on this course. Tactical reverse to gate six. I bet it would not have been do able to turn with that grip. Stupid reverse on the second bonus though. Always little things to improve. Kuva
Fanatic RC Course - (-29/-40)
https://www.youtube.com/watch?v=Rfr0xPqEzt0
For me this was the worst course of the day. One really stupid reverse before gate ten and one none driven bonus. I didn't go for it after seeing what happened to David. It looked too tricky to gain any points.
Holmes Hobbies Course - (-37/-40)
https://www.youtube.com/watch?v=Un5mSCOjh0Y
In this course I made a small mistake by reversing too far at the approach to bonus. That's why I made one extra reverse. Could have ended up lot worse though. Kuva Another tactical reverse to gate ten and it's another progress!! Kuva
Crawler-Keller Course (-40/-40)
https://www.youtube.com/watch?v=b4s-z1CeJoM
Un-Bolt from Norway did this course. For me honestly it looked really tricky before I went for it. Tricky, but do able. Kuva Everything went as planned and I was able to make perfect run from here. I was stunned how well the little one could climb these steep cliffs.
Team Ottsix Course (-36/-40)
https://www.youtube.com/watch?v=jtNMhtp8CXs
This course was easily the hardest of the day. Lot's of steep sidehill gates and some, which I wasn't too sure about. The second bonus was a real killer though. David drove it before me and made it look easy. I went for it and wasn't sure if it's drive able even after few reverses. Luckily though the grip was found and I cleared it after four reverses. Kuva
RcBros Course (-38/-40)
https://www.youtube.com/watch?v=MB1fKG2J3oQ
This was the course, that I made first in the morning with just headlight as my company. Turned out to be suprisingly hard. Kuva It took me two reverses to clear it and I was one happy guy after gate ten. I love this rig!! KuvaKuvaKuva
Counting points at the beach restaurant. Kuva
Victory with 25 point difference to David. That was one tight comp! Kuva
Congrats to David for the second spot and our team chief Tobias for making it 3/3 to SuDu Zero!! Kuva
Here are the results.
Feels good to be back on top in 1.9 class! Kuva
I have absolytely ZERO complains of the performance! Kuva
And I really did have good time in Spain! Kuva
A big thanks goes to all the sponsors, who stepped up for supporting the very first EuroCrawl. Hats off. Kuva
Big thanks to everyone that helped me during the weekend. It really means everything to me. Kuva Allthough this was only the first comp of this rig's career it's time to thank my sponsors:
DravTech
RC4WD
Ottsix
PURPMART
Offipaita.fi
Krawler Konceptz
Joined effort pays off! Kuva Next stop for this rig is hopefully some comp in Finland during next spring. If not, we will see Vätte in the Nordics next time. Kuva
Viimeksi muokannut Zarizi Tech, Ti 08.12.2015 19:48. Yhteensä muokattu 1 kertaa.
Vs: Vätte
A long time since last message, but it has been a long brake since the last comp too. We opened the 2016 season in east in Lappeenranta, which was the first event of Finnish RC Crawling Series.
Beautiful weather and dry rocks kept the drivers entertained for the whole day.
Unfortunately we only had three drivers and one of them wasn't even able to start the comp. So it was me and Sofi who fought our way on one single course. Kuva
I was able to clear the course with seven reverses, but Sofi had to do few more and a roll over.
All in all, good practise even though only one course. Kuva
https://www.youtube.com/watch?v=gVPGNXS1RhI
Here is my performance from the only course we ran. The zero training is easily spotted on those reverses. Have to drive more.
And here are the results. Kuva
I'll continue updating this thread next with The Nordics 2016! Kuva
Viimeksi muokannut Zarizi Tech, Ti 28.06.2016 12:22. Yhteensä muokattu 1 kertaa.
Vs: Vätte
Next it was time to prepare for the 2016 Nordics. Kuva
Checked the screws and everything seemed to be in order.
The whole weekend in Sweden offered fantastic weather. Sunny +30 degrees every single day! Kuva
Unfortunately I have zero pics from the comp itself, but fortunately we have video corner! Kuva
Krawler Konceptz Course - (-10/-20)
https://youtu.be/6uGPGXfEZWU
This was the first course and already on the second gate I hit a marker. It was incredibly slippery down there at some points, but still it was unnecassary gate to hit. Rest of the course went as it should and I was still able to score the best points of this one! Kuva
Dlux Fab Course - (-18/-20)
https://youtu.be/LVp3pT9_GGQ
This was already better course for me. Only one stupid reverse due stupid approach. I'm stunned how well this rig deliveres time after another. Kuva
DravTech Course - (-20/-20)
https://youtu.be/b47kfmWNjBg
This course was the easiest of the day. Couple of harder gates here and there, but nothing that this little rig couldn't handle. Perfect score! Kuva
RcBros Course - (-20/-20)
https://youtu.be/-QcWfhvmO40
This course had many tricky gates, but I think that at last here, my driving came perfectly together. Perfect score and nothing to worry about. Pretty happy about this one too! Kuva
Three comps - three victories!
Good to have DravTech represented well on the podium again! Kuva
Not ultimate victory, but still. Only two "mistakes" on the comp that I could've done other way, so I'm pretty happy.
Really cool trophy to be added on the shelf!  8)
Next comp will be held on 23rd ofthis month in Jämsä and it'll be the second round of Finnish Series for the mini class. Kuva
