Smurfette
Smurfette
Smurfette
Technical stuff:
Akselit: Axial XR-10
Runko: ClassiCutCustoms Mutt
Linkit: CCC Titanium
Moottorit: Holmes Hobbies 400 Pullers
Noparit: Castle Creations Micro Sidewinders
Bec: Castle Creations 10A
Servo: Futaba BLS157HV
Akut: Gens Ace 450mAh 25-50C 3S LiPo
Renkaat: E.Y. Designs Narrowed Ottsix Voodoos (Narrow golds front and ultra narrow silvers rear)
Vanteet: Dlux Solid Face CF (0.87" front and 0.72" rear)
Foamit: Crawler Innovations Double Deuce (5.5" front and 6.0" rear)
Iskarit: Axial SCX10 original
Jouset: Team Losi Mini Crawler silver in front / Team Losi Mini-T Rear blue on rear
Radiot: Sanwa MT-4
Paneelit: Krawler Konceptz
Muuta:
Akselit:
VP wraith knuckles
Axial plastic chubs with brass inserts
VP upper front link mounts front and rear
5th Dimension missing link mounts (shaved)
RC4WD delrin big outer bearing case w/axial case
VP motor plates (drilled for lw)
Dlux 70* universals
CW Crawlers 7075 arms
NCD 4mm Ti steering tie rod
NCD knuckle weights
NCD front battery mount
Custom 7075 drag link
Rowdy Racing motor mounted electronics plate
Axial lw gears
Axial front case fr and rr
Boca bearings in gear cases
CreeperBob TI rear shafts
Blue al. hardware everywhere possible
Custom Fiber motor guards
Runko/jousitus:
Teflon modified skid (freshly replaced)
Custom dlux 3/16 cross braces
CC Ti lower links
Custom 1/8" grade5 Titanium uppers
Rpm rod ends
Traxxas lw suspension balls
Scx shocks (25wt oil, silver mrc springs fr/ silver mrc springs rr, machined pistons, cf spring cups made by AlexG)
Sniper Fab delrin link sliders
Sijoitukset:
2016:
RC Crawler Worlds (World Championships) La Couronne, Ranska: 44
Finnish RC Crawling Series #1, Lappeenranta: 7
RFOT's Crawl Cup #2/6, Vantaa: 4
RFOT's Crawl Cup #4/6, Pirkkala: 7
RFOT's Crawl Cup #6/6, Lappeenranta: 5
LRCC Talvikisa, Lahti: 9
4th Fence Puzzle, Säkylä: 4
Finnish RC Crawling Series 2016: 16
Championnat RC Crawler France: 62
RFOT's Crawl Cup 2016: 8
2015:
EuroCrawl (European Championships) Almuñécar, Espanja: 21
Finnish RC Crawling Series #1, Kuopio: 7
Finnish RC Crawling Series #3, Nokia: 6
Finnish RC Crawling Series #4, Kotka: 8
Finnish RC Crawling Series #5, Rauma: 3
RFOT's Crawl Cup #1/12, Kangasalan Keidas: 3
RFOT's Crawl Cup #2/12, Lahti Bunker: 6
RFOT's Crawl Cup #3/12, Karhusuo: 7
RFOT's Crawl Cup #5/12, Rauma: 3
RFOT's Crawl Cup #10/12, Lahti: 2
RFOT's Crawl Cup #11/12, Koukkujärvi: 4
Finnish RC Crawling Series 2015: 6
RFOT's Crawl Cup 2015: 3
2014:
2nd Fence Puzzle, Karhusuo: 3
Kisoja takana: 19
#2: 1
#3: 4
#4: 3
#5: 1
#6: 2
#7: 4
#8: 1
#9: 1
#21: 1
#44: 1
Viimeksi muokannut Zarizi Tech, Ke 16.11.2016 08:06. Yhteensä muokattu 1 kertaa.
28x Finnish Champion
Re: #96 Smurfette
It's time for my sister to step up to the pro class alongside with 2.2's. Kuva We got good deal from Hittman and got his old CCC Mutt. Thanks to him! Kuva
Rig came down to cold Finland today. Good packing there Christian! Kuva
Someone has been waiting for it! Kuva
What do we have here?
Some CCC magic is already noticed! Kuva
Here   are the stuff that we got from Hittman. It's a really good platform to   start building the dream car. All except the electronics.
All of the stuff are in great shape. Kuva
Rear axle ready to be attached back to the Mutt. Kuva
Front axle is as well. I might go for a little less caster, but that's about all I will change.
These   are one of the tires that will be used under this rig. The other ones   are LaaLaa Skinny Rovers and E.Y Design narrow voodoos. Kuva
Skins have already been designed by Michelle from Krawler Konceptz! How orsome are these?! KuvaKuva
Now   we have the whole autumn to build this thing, and may start competing   with it next year. To the electronics, I've made a decision to go for   Holmes Hobbies this time. More will come, when the rig is taking it's   shape. Kuva
Re: #96 Smurfette
Upea saada taas yksi proovehje messiin! Tulevaisuus näyttää hyvältä, kun RFOT's Crawl Cup pääsee kans poroilee!
+ saadaan suomensarjaankin lisää harrastajia   ;) Näyttävä pirssi ja paneelit 5/5!
R1pp3r T
Re: #96 Smurfette
Viesti Kirjoittaja R1pp3r T »
Hienoa että harrastajia on ja tulee lisää, täytyis varmaan itsekin alkaa harrastaan oikeen kunnolla.
Tosin... kun pienempänä kattelin smurffeja niin en kyllä muista että Smurffiina olisi ollut noin rintava mitä skineissä...
;D ;D ;D
SlidSlide
Re: #96 Smurfette
Re: #96 Smurfette
;D ;D
Softy
Re: #96 Smurfette
Viesti Kirjoittaja Softy »
Upeeta päästä ajamaan viimein sitä kuninkaiden luokkaa. Ilman Samun ehdotusta en tuskin olisi vielä aloittanut ajamista, mutta mitä sitä turhaan odottaa?
Viimeviikonloppuna sain ekaa kertaa kokeilla pro autolla ajamista. Ajaminen kyllä yllätti odotukseni. Olen aina pitänyt pro luokkaa ns. " mahdottomuutena" Mutta sitä se ei ollut. Harjoittelua se tottakai vaatii, mutta pikkuhiljaa hyvä tulee. Vaikka auto onkin vielä kokoamispisteessä niin eiköhän siitäkin hyvä tule, tai siltä se ainakin vaikuttaa. Odotan innolla, että pääsen kokoamaan autoa ja harjoittelemaan. Suurimmaksi osaksi tämänkin luokan ajot taitavat jäädä ensi vuoden puolelle. Ensi vuonna sitten täysillä taas kilpailemaan!
P.s. Huom! Paneelien on tarkoitus häiritä   muita kuskeja, kun kerran näin miesvaltaisessa lajissa ollaan.   ;)
[align=center]Sofi Sarka, RFOT, FIN
Holmes Hobbies ~ Ottsix ~ RC4WD ~ Offipaita ~ Zarizi Tech[/align]
Re: #96 Smurfette
Paneelit ovat piste i:n päälle. Todella asialliset tuohon projektiin ja onnea uuteen luokkaan.
macman
Re: #96 Smurfette
Viesti Kirjoittaja macman »
Smurfantastic   8)
RaumRC
Re: #96 Smurfette
Work continues... Sofi assembled the rig together:
I told her to be careful with them aluminium screws. Kuva
Refreshment.
Loosing the nerves assembling washers. Kuva
Axles assembled.
It's just waiting for the electronics. They are coming soon! Kuva
Tires!
That's how it flexes. Really smooth!
It's just waiting now. This will be on the comp in this season. That's for sure! Kuva
Re: #96 Smurfette
While we have been waiting for the other electronics to come in stock again, Sofi has been training with my pro and building the things she can for now. Kuva
First competition with pro rig. Still unfamiliar with two ESC's, but the driving seems to be there. Just requires lot of training as in with any other driver. Kuva
So, time to start skinning Smurfette! Kuva
As it turned out, the Mutt wasn't in original wideness, when it left from NM. Kuva Time to make it wider. Sofi didn't want to cut the skins, which is highly acceptable in this case. Kuva
Still smiling...
After two hours... Kuva
Few still to attach. Turned out to be a really tricky job to find parts to make this wider.
Windows!
Colour seems to be perfect for this thing! Kuva
Attaching the inner skin, to protect electronics.
Shiny! Kuva
She is on! Kuva
After three hours it's done. Almost. Still need to bend front of the roof.
Damn, it looks good! Kuva
Roof from behind.
Here is what it's gonna look like when climbing. Kuva
Smurfette wants to thank Holmes Hobbies for the shirt. Kuva
Now it's time to wait for the electronics. Might take a while. Plan is to get it going in next two months. Kuva
Viimeksi muokannut Zarizi Tech, Pe 03.10.2014 19:19. Yhteensä muokattu 1 kertaa.
Re: #96 Smurfette
On kyllä upeet paneelit! Eikä se ensimmäinen prookisakaan hassummin mennyt, siellä on kyllä "ajatus" tekemisestä, joten jatkossa saadaan hyvää mättöö!   8)
SlidSlide
Re: #96 Smurfette
Auto näyttää todella hyvältä ja persoonalliselta.
Re: #96 Smurfette
Time for update.
After I heard, that the next batch of ESC's will take time to arrive from Holmes Hobbies, I decided to tare apart my own electronics from the bully. This way Sofi could have her first comp in this year. Kuva So, it was time for preparations.
Old trusted servo from my ex-mini crawler. Futaba BLS157HV. Kuva
I also bent the roof panel and now it looks really mean! Kuva
Stubbies, micro sidewinders and CC Bec ready to jump on XR-10.
Steering in place.
And it steers! Kuva I also gave my E.Y. Designs narrowed Voodoos to Sofi's rig. Dlux wheels and those tires are perfect match for the rig. Kuva
Rear motor attached.
Overall look before attaching rest of electronics. Kuva
Overall RTR weight is impressive as well! Kuva
Electronics are finding their place.
Pretty cool this thing. Kuva
Electronics are on the place. Even the battery is perfect match for the colours of this thing! Kuva
Mutt gives you a decent amount of ground clearance as well. Kuva
I have to say, that Michelle did amazing job with the skins. Again! Kuva
Then it was time for the comp. The last one in our season 2014. Fence Puzzle! Kuva
Sofi did not have a clue, that her rig would be in action already there. It was great to see her face, when she saw the finished product. Kuva Priceless. Kuva
Time to get the party started! Kuva
On the line for the course!
Nervous?
First gate - cleared!
The ride looked really good!
Going for the difficult gate four. Kuva
Rig was working flawless through the comp. Nothing broke and Sofi did few amazing performances! Kuva
There was only one thing, which I found out that needs changing. That's the caster angle. In my opinion it had way too much positive caster. But that's about all, that I would change of it so far. Kuva
https://www.youtube.com/watch?feature=p ... SST9E6LKn8
Here video from the second course, where Sofi only took two reverses! She decided not to go for the bonuses, but just go on the finish line. Wise descision. Kuva
Here are the results! Kuva Third position with a brand new rig. That's the spirit! Kuva
After the comp, I went to garage to "fix" the only problem it had with the caster angle.
One step back. Kuva
It still steers pretty well.
I think this is going to improve the steering quite a bit at least in Finland. Kuva
Now we'll just have to test it, when we have a suitable weather to do that. It's getting colder here day by day. Kuva Next comp will be on January and the tuning will start from there. At least it's good, that Sofi has now driven a few gates with this before the new season. Kuva
We'll continue on working.
PICTURES: Arttu Ahtiainen
Viimeksi muokannut Zarizi Tech, Ma 10.11.2014 18:35. Yhteensä muokattu 1 kertaa.
Softy
Re: #96 Smurfette
So, first comp behind. I have to say that I was completely surprised when Samu brought my car with his electronics on it. It was a really nice surprise so thanks bro! Kuva Driving with smurfette was kind of easy thanks to my chassis CCC Mutt which is by the way brilliant! It is hard to describe how good it feels to drive with that car. I think that word smooth could gave you the best description. Everything works amazingly! Still it is hard to use all the buttons which I have never used because I've been driving shafty class. So my driving is kind of slow. My first comp went well. Still, I've got pretty good drivers to challenge me but I think that is a good thing! It's good to have some challenge Kuva Smurfette rocks! Still, looking forward to the next season! My brother is spending a lot time with that car but I think he has to step aside because I want to repair my rig all by myself, of course ;)   So, now it's time for training for the next season.
Re: #96 Smurfette
We have rest of the parts now! Kuva
Some batteries for next season...
And two Holmes Hobbies 33T 400 Pullers ready for installing. It's gonna be ready soon! Kuva
Later, when the new version of HH BR-Minies arrive, Sofi will change to those. For now we are going with Micro Sidewinders.
Re: #96 Smurfette
Finally got myself back to the garage and doin some work. Kuva
After checking out all screws and bearings in the axles and chassis, the electric works needed to be started.
"Koppensneller's" old electronics will head down into this rig. I gotta clean those wires a bit.
And of course the brand new Holmes 400 Pullers. Kuva
CF motor guards are also waiting for assembling.
Rear motor attached!
Daaarn, this rig is just blue'ish symphony! Kuva
Everything looked excellent in the axle as well. Kuva
Front axle in the place now as well.
Also added a Rowdy Racing electric mount for ECS's and BEC.
Everything went on flawlessy! Kuva
I removed the cases of Sanwa receiver and put the BEC into a same cute package with ESC's. Kuva
Final stretch still to go! Have to clean up the wires before installing the whole thing in the rig. Slooooooowly, but steadily! Kuva
Re: #96 Smurfette
Another day at garage. Kuva
Time to make them wires longer and clean them up.
Carbon fiber motor guards on the place protecting them Pullers. Kuva
Looks awesome! Kuva
This build has been a really easy with no drama. Simply enjoyable tuning. Kuva
Still trying to make them colors match! Kuva
God I hate soldering.... Kuva
Ready for testing! Kuva
Didn't smell any smoke in the test, but also realized that the TX is not in the setup. Gonna do the testdrive later then.
I think I got them there quite nicely.
ESC's and BEC are now on the Rowdy Racing electronic mount and RX is in the chassis. Kuva
Suspension in normal driving situation.
Front dig on. Suspension all the way down. The ESC package isn't touching the hood. I made it!! KuvaKuva
Gotta say I'm proud of my work today. Kuva Only testing to do before the first comp! Kuva
Re: #96 Smurfette
Beautiful build, very inspiring!
SlidSlide
Re: #96 Smurfette
Yeah, got me a stoge!
