Technical stuff:
Akselit: Axial XR-10
Runko: ClassiCutCustoms Mutt
Linkit: CCC Titanium
Moottorit: Holmes Hobbies 400 Pullers
Noparit: Castle Creations Micro Sidewinders
Bec: Castle Creations 10A
Servo: Futaba BLS157HV
Akut: Gens Ace 450mAh 25-50C 3S LiPo
Renkaat: E.Y. Designs Narrowed Ottsix Voodoos (Narrow golds front and ultra narrow silvers rear)
Vanteet: Dlux Solid Face CF (0.87" front and 0.72" rear)
Foamit: Crawler Innovations Double Deuce (5.5" front and 6.0" rear)
Iskarit: Axial SCX10 original
Jouset: Team Losi Mini Crawler silver in front / Team Losi Mini-T Rear blue on rear
Radiot: Sanwa MT-4
Paneelit: Krawler Konceptz
Muuta:
Akselit:
VP wraith knuckles
Axial plastic chubs with brass inserts
VP upper front link mounts front and rear
5th Dimension missing link mounts (shaved)
RC4WD delrin big outer bearing case w/axial case
VP motor plates (drilled for lw)
Dlux 70* universals
CW Crawlers 7075 arms
NCD 4mm Ti steering tie rod
NCD knuckle weights
NCD front battery mount
Custom 7075 drag link
Rowdy Racing motor mounted electronics plate
Axial lw gears
Axial front case fr and rr
Boca bearings in gear cases
CreeperBob TI rear shafts
Blue al. hardware everywhere possible
Custom Fiber motor guards
Runko/jousitus:
Teflon modified skid (freshly replaced)
Custom dlux 3/16 cross braces
CC Ti lower links
Custom 1/8" grade5 Titanium uppers
Rpm rod ends
Traxxas lw suspension balls
Scx shocks (25wt oil, silver mrc springs fr/ silver mrc springs rr, machined pistons, cf spring cups made by AlexG)
Sniper Fab delrin link sliders
Sijoitukset:
2016:
RC Crawler Worlds (World Championships) La Couronne, Ranska: 44
Finnish RC Crawling Series #1, Lappeenranta: 7
RFOT's Crawl Cup #2/6, Vantaa: 4
RFOT's Crawl Cup #4/6, Pirkkala: 7
RFOT's Crawl Cup #6/6, Lappeenranta: 5
LRCC Talvikisa, Lahti: 9
4th Fence Puzzle, Säkylä: 4
Finnish RC Crawling Series 2016: 16
Championnat RC Crawler France: 62
RFOT's Crawl Cup 2016: 8
2015:
EuroCrawl (European Championships) Almuñécar, Espanja: 21
Finnish RC Crawling Series #1, Kuopio: 7
Finnish RC Crawling Series #3, Nokia: 6
Finnish RC Crawling Series #4, Kotka: 8
Finnish RC Crawling Series #5, Rauma: 3
RFOT's Crawl Cup #1/12, Kangasalan Keidas: 3
RFOT's Crawl Cup #2/12, Lahti Bunker: 6
RFOT's Crawl Cup #3/12, Karhusuo: 7
RFOT's Crawl Cup #5/12, Rauma: 3
RFOT's Crawl Cup #10/12, Lahti: 2
RFOT's Crawl Cup #11/12, Koukkujärvi: 4
Finnish RC Crawling Series 2015: 6
RFOT's Crawl Cup 2015: 3
2014:
2nd Fence Puzzle, Karhusuo: 3
Kisoja takana: 19
#2: 1
#3: 4
#4: 3
#5: 1
#6: 2
#7: 4
#8: 1
#9: 1
#21: 1
#44: 1
I also gave my E.Y. Designs narrowed Voodoos to Sofi's rig. Dlux wheels and those tires are perfect match for the rig.
