Team Losi Rock Claws
RunWild81
Viesti Kirjoittaja RunWild81 »
Tuli nyt tuommoiset hommattua. Nopean sisätestin perusteella pito on aivan mieletön. Lisää juttua kun päästään ulos asti testaamaan. Kietaisin clawsit beadlock vanteille ja vertailtuna moabin kanssa tuntuvat hieman pehmeämmiltä ja hieman korkeammalta. Napsin kuvia molemmista samalla vanteella.
Losi Rock Claws Tires ... have just won the 2007 USRCCA Climbing Championships!!
The USRCCA Rock Crawling National Championships were held in Moab, Utah from September 7th - 9th.
At the Nationals, the drivers who placed 1st, 2nd, 3rd, and 5th all used the new Losi 2.2” Rock Claws!
These new tires were so popular at the event that it is estimated that 70% to 80% of the entire field were using the new Losi Rock Claws!!
Että ei ainakaan pitäis olla mikään huono rengas valinta
# allows for ½ inch of additional clearance over standard 2.2” truck tires
# multi-edged tread design enhances traction by simultaneously gripping in multiple planes on uneven surfaces
# large lug design helps for self-cleaning removing mud and dirt giving enhanced traction
# comes in Losi’s sticky “B” (Blue) compound and will fit any common 2.2” rim making it useful for both stadium type trucks and highly modified rock crawlers
Losi helps truck and rock crawling enthusiasts get a grip on the roughest terrain with their new LOSA7682B “Rock Claw” tires. The Rock Claw is a 2.2 1/10th Scale Truck tire that has been developed to deliver the combination of multi-edge tread design, high-grip soft compound, and a rock conforming carcass needed to out-perform the current crop of popular designs. These purpose built tires are 5” tall and 2.2” wide making them the biggest tire Losi has ever made for 1/10th scale trucks. The new tire size allows for ½” of additional clearance over our standard 2.2” truck tires. The unique design was inspired by the Aftershock Monster truck tire with key design features incorporated in the tread and carcass to allow you to aggressively attack uneven and rocky terrain. The creative multi-edged tread design enhances traction by simultaneously gripping in multiple planes on uneven surfaces much like that of fingers gripping a rock. The large lug design also helps in cleaning itself from mud and dirt giving enhanced traction is these types of conditions. The LOSA7682 “Rock Claw” comes in Losi’s sticky “B” (Blue) compound and will fit any common 2.2” rim making it useful for both stadium type trucks and highly modified rock crawlers.
joska
Vs: Team Losi Rock Claws
Viesti Kirjoittaja joska »
on kyllä hyvät renkaat.tänään tuli ja on jo koe ajettu noi renkaat ja niissä on todella hyvä pito
rc4wd,axial,spektrum
http://www.racingfactory.fi
http://www.rc-garage.fi
http://www.sabe.fi
J-P H
Viesti Kirjoittaja J-P H »
Kyllä noilla renkailla pärjää tosi hyvin, yhtä hyvät kuin badlansit. Vaikka nyt näyttää siltä että badlansit valtaa alaa.
Itse olen ollut tyytyväinen rock clawsiin ja taytyyhän merkkihäiriköitäkin olla mukana.
2x4 4x4 6x6
kenni_
Viesti Kirjoittaja kenni_ »
Mistä kaupasta näitä löytää kun ei tunnu kävelevän oikein missään eteen, vaikka kuinka etsii...   :-\
-kaikki muu paitsi crawling on turhaa-
klrp
Viesti Kirjoittaja klrp »
Krapula Cup champ '08
Muna Cup driver '09
J-P H
Ulkomailta ainakin http://www.liquidrc.com
2x4 4x4 6x6
kenni_
Nyt on kumit ja toiset vanteet tilattu. Mahtaakohan niissä tulla foamit mukana kun ei ainakaan lukenu, mut kuvassa kyllä oli.
Saapi nähä onko millaset verrattuna M3 seoksen Hammereihin.. on noita ainakin kehuttu kovasti joka paikassa, saa nähä vaan onko kehuttu liikaa... :-\
klrp
Jaa-a, hammerithan on ainakin paskat, ainot kunnon kilpakumit Badlandsit ja Rock Clawsit.
Muna Cup driver '09
SlidSlide
klrp kirjoitti: ainot kunnon kilpakumit Badlandsit ja Rock Clawsit.
En voinut olla kommentoimatta, kun ohjattiin kokemattomampaa.
Mihin unohtui Panther Cougarit?.. Foamisetup hieman vaikeahko hakea, mutta sen löydyttyä lyö badlandsit.
bartti
Viesti Kirjoittaja bartti »
SlidSlide kirjoitti:
Lappalan topicista lainattu Assoracing 3.sija kommentti
assoracing kirjoitti: Kilpailut takana, sää oli hyvä vaikka sadetta oli luvattu. Radat oli "melko" haastavia ja tais järjestäjät olleet jo hinkanneet kiviä joskus muulonkin   :P Paikallahan oli 8 kilpailijaa joista 2 virosta. Lisää tällaisia !! Nyt tuli todetuksi että ei Panttereilla pärjää Badlandslle.
Viimeksi muokannut bartti, La 04.10.2008 20:49. Yhteensä muokattu 1 kertaa.
2014  Finnish scale class2 #1
kenni_
No hohhoijaa, olipas kommentti.    ???
Ilmeisesti olet sitten itse päässyt vertaamaan hammereita ja badlandseja/rock clawsseja?
Kyllä ainakin omassa rassissa mielestäni ihan hyvin toiminu noi hammerit. Tosin vertailupohjaa ei oo mutta ei noi nyt mitkään ihan kusiluistimet oo.
Viimeksi muokannut kenni_, La 04.10.2008 09:43. Yhteensä muokattu 1 kertaa.
SlidSlide
bartti kirjoitti:
Lappalan topicista lainattu VOITTAJAN kommentti
Milläs foameilla assoracing ajoi?
Se foamisetup pitää hakea kokonaan erikseen. Sitten cougarit pääsee vasta oikeuksiinsa.'
Edit:
Ylipäätäänkin useat renkaat on ihan kelvolliset, jos hieman viitsii panostaa foameihinkin.
En puhu nyt ainoastaan leikkaamisesta, vaan myös kokonaan toisenlaisen foamityypin hankkimisesta
sekä hienosäädöstä: päällekkäin laitoista, leikkauskuviosta yms..
Viimeksi muokannut SlidSlide, La 04.10.2008 12:21. Yhteensä muokattu 1 kertaa.
klrp
SlidSlide kirjoitti: Ylipäätäänkin useat renkaat on ihan kelvolliset, jos hieman viitsii panostaa foameihinkin.
Joo, siis crawlingissa toimii kaikki crawlingiin tarkoitetut kumit hyvin verrattuna joihinkin perusbashingkumeihin, kun löytää hyvän setupin oman autonpainolle, etc.... Mutta silti näilläkin on eroja, pieniä sellaisia (kun verrataan puhdasta kalliota, sammaleista, hiekkaista, märkää..), mielestäni Badlands > Moab/Hammer/Flat Iron ja Rock Claws > Panther Cougar.
Tällä hetkellä omaan rengastukseeni kuuluu Badlandsit, Moabit ja Rock Clawsit. Jokainen ajakoot millä tykkään, parempi vaan että kaikilla ei ole voittaja Badlandseja. Kuva
Muna Cup driver '09
Re: Team Losi Rock Claws
Uppia..
Onko Comp Clawseilla muuta eroa Rock Clawseihin kuin koko? Onko merkittävää eroa kummat noista ostaa?
HMS77 kirjoitti: Uppia..
Jos ei Losia ole pakko olla niin hanki kerralla kunnon renkaat kuten valkoiset Roverit tai Sedonat.
Tomy kirjoitti: Jos ei Losia ole pakko olla niin hanki kerralla kunnon renkaat kuten valkoiset Roverit tai Sedonat.
Joo ei Losi ole mikää pakko, satuin vaa kattelee renkaita huvikseni Sabelta ja huomasin tuollasen omituisuuden.
Mutta käsittääkseni nuo Rock Clawsitkin on todella hyvät renkaat ja sillä aloin ihmettelemään josko noissa kahdessa on muutakin eroa kuin koko.
Taitaa kuviossakin olla vähäisiä muutoksia kasvaneen halkaisijan lisäksi. Varmasti toimii CompClawsitkin hyvin. Viime kauden ykköset oli Roverit ja tästä kaudesta ei vielä tiedä. Etelän miehet ovat foorumin perusteella aika paljon käyttäneet Sedona-renkaita.
Hmmh... pitääpä nyt sitten kattoa mitkä ostaa. Sabesta sais vaan kätevästi nuo Clawsit parissa päivässä..
Ei sillä että mulla mitää pakkoa ois saada parempia gummeja Lahteen, kunhan huvikseni tässä..   :-X
Pasi
Viesti Kirjoittaja Pasi »
http://www.rc-offi.net/smf/https://www. ... ic.php?t=6
Siinä ois melkeen uudet pyörylät ;)
EDIT. Jos pinkit ex-roverit kiinnostaa ni kannattaa kysyä oisko näitä vielä jäljellä http://www.rc-offi.net/smf/https://www. ... ic.php?t=7
Viimeksi muokannut Pasi, To 13.05.2010 15:45. Yhteensä muokattu 1 kertaa.
SlidSlide
Comp Clawseista saa huhujen mukaan äärimmäisen suorituskelpoiset renkaat pienillä muutoksilla. Renkaan pinnasta on poistettava kumia, jotta maksimaallistettaisiin pito. Täällä ei taida olla kukaan kokeillut kyseistä modausta.
Ilman muutoksia Roverit on varmasti paremmat.
