Että ei ainakaan pitäis olla mikään huono rengas valintaLosi Rock Claws Tires ... have just won the 2007 USRCCA Climbing Championships!!
The USRCCA Rock Crawling National Championships were held in Moab, Utah from September 7th - 9th.
At the Nationals, the drivers who placed 1st, 2nd, 3rd, and 5th all used the new Losi 2.2” Rock Claws!
These new tires were so popular at the event that it is estimated that 70% to 80% of the entire field were using the new Losi Rock Claws!!
:-*# allows for ½ inch of additional clearance over standard 2.2” truck tires
# multi-edged tread design enhances traction by simultaneously gripping in multiple planes on uneven surfaces
# large lug design helps for self-cleaning removing mud and dirt giving enhanced traction
# comes in Losi’s sticky “B” (Blue) compound and will fit any common 2.2” rim making it useful for both stadium type trucks and highly modified rock crawlers
Losi helps truck and rock crawling enthusiasts get a grip on the roughest terrain with their new LOSA7682B “Rock Claw” tires. The Rock Claw is a 2.2 1/10th Scale Truck tire that has been developed to deliver the combination of multi-edge tread design, high-grip soft compound, and a rock conforming carcass needed to out-perform the current crop of popular designs. These purpose built tires are 5” tall and 2.2” wide making them the biggest tire Losi has ever made for 1/10th scale trucks. The new tire size allows for ½” of additional clearance over our standard 2.2” truck tires. The unique design was inspired by the Aftershock Monster truck tire with key design features incorporated in the tread and carcass to allow you to aggressively attack uneven and rocky terrain. The creative multi-edged tread design enhances traction by simultaneously gripping in multiple planes on uneven surfaces much like that of fingers gripping a rock. The large lug design also helps in cleaning itself from mud and dirt giving enhanced traction is these types of conditions. The LOSA7682 “Rock Claw” comes in Losi’s sticky “B” (Blue) compound and will fit any common 2.2” rim making it useful for both stadium type trucks and highly modified rock crawlers.
