HPI Wheelie King Crawler Conversion
RunWild81
Tuli aussien joltain sivulta kaapattua
HPI will soon offer a kit to convert the Wheelie King to a crawler. The kit will come with new suspension links and mounts as well as a new crawling specific gear set. The wheels are HPI beadlocks and although ProLine tires are shown on this truck, HPI will have their own crawler tires.
klrp
Vs: HPI Wheelie King Crawler Conversion
Viesti Kirjoittaja klrp »
Noi rock ringit näyttää ihan sellaisiltä mitkä niissä Junfacin beadlockeissa. :o Toivottavasti eivät tee mitään paketti missä nuo kaikki osat ja myy sitten 200e sitä.
Krapula Cup champ '08
Muna Cup driver '09
RunWild81
CRAWLER CONVERSION SET COMING FOR THE HPI WHEELY KING!
If you haven’t tried rock crawling yet, HPI has a quick and inexpensive way to get into the sport. Coming soon from HPI Racing is a conversion set that transforms the popular Wheely King truck into the latest craze in R/C… a rock crawler!
The conversion set lengthens the wheelbase by 2 ¼”, taking it to the maximum allowed by the rules to help provide the stability needed for extreme rock crawling. Anodized aluminum lower links are durable and give the Wheely King an authentic crawler looks and ground clearance is extended with high link suspension mount brackets.
To help maximize the weight layout for rock crawling, the conversion set comes with a new servo mount that allows the battery to be moved forward in the truck. Diff lockers are included to for both differentials, effectively locking the front and rear diffs for extra traction. Also included are convenient body mounts and hex hubs that allow the Wheely King Crawler to be compatible with a wide variety of bodies and wheels.
CRAWLER CONVERSION SET FEATURES:
    * 2 1/4" longer wheelbase for better stability.
    * Longest wheel base allowed by class rules.
    * Diff Lock (Front and Rear) for increased traction.
    * Front battery layout moves weight forward for better crawling stability.
    * Additional body mounts allow fitment of all Savage bodies.
    * Aluminum lower suspension links for extreme durability and good looks.
    * High link suspension mount brackets for more ground clearance.
    * New Steering servo mount repositions servo to allow battery in front of crawler.
    * Optional 17mm hex hub included for fitment of 17mm hex hub wheels. (Savage wheels etc.)
http://hpiracing.com/products/en/87633/
RunWild81
Make your own King crawler!
Rock crawling is the latest RC craze to hit 4-wheel vehicles, and instead of the high-octane, adrenaline-fueled craziness of drifting from Japan, this low-speed, thrill-packed off-road adventuring comes from the mountain areas of America!
So what is crawling about? In stark contrast to the often two-dimensional world of circuit racing and drifting on pre-made, unchanging tarmac tracks, crawling gets you to attempt the improbable by attacking near-vertical cliffs, slick rock faces and piles of mountain rubble! Boulders, rock piles, mountain trails and footpaths are the typical location for competitions or fun meetings. Although in competitions the truck owners compete against each other, the magic appeal of rock crawling is that each driver competes against their own abilities, trusting in the strength of their equipment and the machine that is bringing them up the hill.
To make crawling more accessible to HPI customers, we’ll be releasing a sweet ‘crawler conversion’ made especially for the Wheely King!
The Wheely King has proven to be extremely popular with hobbyists, and it’s also become a great project truck for crawling enthusiasts to start a custom crawler build with. To make things even easier for crawling maniacs to get started, the Wheely King Crawler Conversion kit has everything that’s needed to convert a 4WD Wheely King into a ‘King crawler’!
The kit includes everything necessary to extend the wheelbase of the Wheely King, which will make it easier to go over obstacles. Extra lower shock mount positions allow you to fine-tune the suspension action for increased traction at both ends of the truck. A bolt-on gear set reduces the gear ratio of the Wheely King to give it more low-end torque to climb over anything. Finally, the chassis is flipped around so the battery is at the front, putting the weight just where you need it to get over and across whatever stands in your way.
    * Complete conversion kit for Wheely King truck – turn any 4WD Wheely King into a hill-climbing monster!
    * Chassis reversed to put battery weight over front axle
    * Extended wheelbase (2.25 inches longer)
    * Aluminium links
    * Extra climbing power with reduced gearing
    * HPI custom beadlock 3-piece wheels
    * HPI crawler tyres
    * Front and rear locked diffs for extra traction
    * New link and shock mounts on axles
    * Can mount servo in standard location or in front of truck
    * Savage body mounts included to fit Savage & monster truck bodies
    * 17mm hex hubs included to fit Savage & monster truck wheels
Extended Wheelbase
For extra stability when crawling up steep inclines, the conversion set includes new longer links that extend the wheelbase significantly over the stock Wheely King. Cool anodized aluminium links with tough pivot balls control the linkage and actuation, giving you loads of articulation for extreme angles!
Super-Low Gearing
To give the motor enough torque to get over boulders, rocks and any other obstacles, the conversion kit will include gears that will drastically lower the drivetrain gear ratio. This makes the Wheely King much slower on level ground, but you will get the full effect of the engine as you encounter steep approach angles and slippery, sandy rocks!
Cool Custom Beadlock Wheels
All-new HPI beadlock wheels will be included to give the Wheely King crawler a sweet custom look and allow you to change wheel weights, foams and tyres whenever you need to. There's nothing like the look and style of real beadlocking wheels, and these new 'mag' style wheels look amazing and perfect for the ultimate sclae crawler look!
New Lower Shock and Link Mounts
To give you the best tuning options, HPI designers have included a new lower shock and link mount with several extra mounting locations. This gives you a multitude of options for tackling the toughest climbs, inclines and rock piles.
Monster Truck Body Mounts
For getting a cool custom style, you can't beat the option of attaching different bodies on your crawler. We've included a full set of Savage-size body mounts for fitting dozens of different monster truck bodies! Simply use your Savage or other monster truck body right on, quick and easy, for a quick style change!
KuvaKuva
KuvaKuva
With the HPI Wheely King Crawler Conversion, you’ll be able to get right out and get crawlin’, or build up the project crawler of your dreams!
Wheely King Rock Crawler Conversion
Full conversion kit for Wheely King, with beadlock wheels, tyres, reduced gearing set, complete hardware and full instructions. Get ready for some monster crawling action!
                              Specification May Be Subject To Change
Viimeksi muokannut RunWild81, To 21.02.2008 10:53. Yhteensä muokattu 1 kertaa.
Osgard
Viesti Kirjoittaja Osgard »
Ihan hyvältä vaikuttaa akku vaan vieläkin väärässä paikassa.
RunWild81
Onhan akku jo sentään keulassa, eikä enään siellä takana.
klrp
Teksteissä puhutaan HPI:n omista crawlerrenkaista, mutta kuvissa moabit, millaisethan on tulossa? ::)
Muna Cup driver '09
RunWild81
[quote="klrp"]
Jostain luin että kumit ja vanteet ei ole vielä valmiit ja noita kuvia varten oli lainattu jostain vanteet/kumit
