Laitteet vesitiiviiksi
RunWild81
Onko mitään hyviä vinkkejä niksejä kellään? Netistä tuli vastaa seuraava artikkeli lontooksi. Suurin osa taitaa jo englantia holdata niin en vaivaudu kääntämään. Itse oon iskareita suojannu ihan pitkulaisilla ilmapalloilla, pitää hyvin puhtaana.
Battery Connections/Exposed Wires
This is an often overlooked area when trying to protect your truck from the elements. You should cover all connections, such as battery plugs, that are exposed to the elements. Otherwise it's possible that moisture could seep into these plugs and short out the two wires. A few pieces of electrical tape should take care of this situation easily, just make sure to surround the entire plug as any small opening could be an entry point for water.
Motor
Believe it or not, in an electric RC, the motor is an area that requires very little attention when exposed to the elements. You don't really need to worry about keeping the moisture away from the elements as water will not affect it's operation. As a matter of fact, in some cases hobbyists run a motor underwater as a way to break the motor in. The only thing you'll need to do is disassemble the motor after running, and clean it well. Make sure you re-lube your motor's bearings or bushings when putting it back together.
Receiver/Receiver Pack
The receiver is generally one of the most expensive components on an RC truck, so you want to make sure you provide it plenty of protection from the elements. Many nitro-powered vehicles already have the receiver protected with some sort of cover or plastic box to avoid damage should nitro splash on it when refueling. However very few electric vehicles offer this sort of protection, and even in the nitro world there are some exceptions.
Many receiver boxes can be used on vehicles other than the ones they were intended for, when used with a little creativity. This provides a good option for protecting your receiver. When using a receiver or battery box, keep in mind there are often small gaps in them. Most of the time, these are the areas that wires pass through. It would be a very wise course of action to seal these gaps up with silicone to prevent water from finding it's way inside.
You can also use a balloon to cover the receiver if this option isn't feasible for you. Simply insert the receiver into a balloon, with the servos already plugged into the receiver in their correct locations. Then close up the mouth of the balloon with a ziptie. You can also seal up the mouth of the balloon with some grease or silicone to help seal up any leftover gaps after the ziptie is pulled tight. While it may not be the most attractive solution, it's very effective. If your truck also uses a receiver pack, or battery holder, to power the receiver you should also protect it as well. Again many trucks provide battery boxes, and those battery boxes can fit many other vehicles besides the ones which they were designed for. If all else fails, a balloon will work well in this area as well.
Servos
Servos are another item that should be protected from the elements. Some servos, such as the Hitec 5625MG and 5645MG, are water-proof and need no further attention. However most servos do need to be protected from the elements. There are two widely used methods to accomplish this, balloons and silicone. Using a balloon is pretty straightforward. First remove the servo horn or servo saver, and then simply encase the servo inside a balloon. Leave the wires sticking outside the mouth of the balloon, and close up the mouth of the balloon with a ziptie. You can also seal up the mouth of the balloon with some grease or silicone to help seal up any leftover gaps after the ziptie is pulled tight. Then use a pin to place a small hole in the balloon where the servo output shaft is located, and pull the balloon so that the shaft slides through it. Then you can reinstall your servo horn or servo saver. Another method of protecting your servo from moisture, is to use some silicone sealant. This results in a stock-like appearance, as you can't really tell that anything has been done to the servo. Take the servo case halves apart, and apply a small bead of silicone where the they connect. Then simply reassemble the case and allow the silicone time to cure. To protect the area around the servo output shaft, use a small o-ring coated with some grease to form a seal when you install a servo horn or servo saver.
Speed Controller
Protecting your speed control is a very important, yet difficult, step to undertake. I often hear of people encasing their ESC inside a balloon, but that's often a dangerous idea. It severely hampers the ESC's ability to cool itself, which could lead to the ESC overheating and damaging itself. At the very least, you might experience the balloon the ESC is encased in melting. So if you choose this method of protection, I would encourage you to frequently monitor your ESC's temperature to avoid such problems. Small plastic project boxes like they sell at radio shack can be used to seal up the ESC or ESC and Receiver too.
The only good solution for a MSC, would be to make a shield to protect the electronics from the elements. You can fabricate something out of scrap lexan, or simply carve up a 2-liter drink bottle. A few pieces of duct tape will hold the shield in place and help prevent any moisture from finding it's way inside. As a general rule, since a shield sits away from the ESC by several inches, the ESC shouldn't overheat with this method. However it would still be advisable to check it from time to time to ensure that it's still not overheating.
It's also possible to buy waterproof ESC's for use during wet and snowy conditions. MTroniks is one company that is well known for this. Also LRP makes water proof ESC's.
Misc. Tips
In addition to the things listed above you can use plastidip found at local hardware stores (it's a liquid that hardens into a rubber coating) and dip your parts in it to seal them, servos are a prime cantidate for plastidip.
Put a thin coating of oil on the outer motor bearing to help prevent water intrusion.
WD-40 can be used on the motor, but use it sparingly, but spray some on a cloth and wipe down your metal chassis parts just like you'd oil a gun and the water will bead right off and it makes clean up a snap. Armorall works also, some people use armorall on the plastic parts. I use rainx on the outside of the body or wipe it with a thin coat of armorall the help make clean up easy.
Most of the info above can be found on:
http://www.misbehavin-rc.com/pit-lan...erproofing.asp
Except for the last few lines I give full credit to them on this article. I use alot of these tips on my Electrics and on my Nitro 4x4's also. So if there is a nitro tip mentioned please take it for what it is.
If you have other water proofing ideas please share them here.
Revoman
Vs: Laitteet vesitiiviiksi
Viesti Kirjoittaja Revoman »
Itse oon käyttänyt silikoonia, kuumaliimaa, muovi spray, 1:1 autoissa käytettävää mustaa sinitarra maista (en muista mitä töhnää on).
Ilmapalloja en oo enään käyttänyt kun ei tahdo kestää.
Jotkut on dipannu valumuovissa servoja, nopareita, vastaanottimia jne.
Edit. Muistin tossa kun lueskelin toista topikkia niin vaseliini on erittäin hyvää tiivistys hommaan. Oon käyttänyt pientä lääkeruiskua jolla saa pursotettua vaseliinin ahtaisiinkin paikkoihin.
Viimeksi muokannut Revoman, Ti 22.01.2008 14:02. Yhteensä muokattu 1 kertaa.
OffiOsku
Viesti Kirjoittaja OffiOsku »
Ei kyllä toi lontookaan onnistu niin ei onnistu ton lukeminen   ???
Onko noi sähköautot kuinka herkkiä vedelle ja kosteudelle?
historia
Viesti Kirjoittaja historia »
No nehän kärähtää melko varmasti jos niitä ei ole suojannut...
OffiOsku
Muita olen koittanut saada suojattua, mutta servo ja moottori on ilman mitään kun ei niihin oikein ole keksinyt mitään..
Onko ne yhtä herkkiä vedelle?
Osgard
Viesti Kirjoittaja Osgard »
Servo on. Moottori ei
Dark Crusher
Kaikki riippuu ihan missä ajaa ja miten. Itse en ole kuuna päivänä suojannut mitään talviajoissa,
eikä ole mitään hajonnutkaan. Antaa sulattua ilmavassa tilassa ja homma pelaa, ei tartte ottaa
turhaa stressiä   ;D
Osgard
Nono! Kannattaa ne sähköt suojata. Ite en kyllä ole jaksanut ikinä mitään suojata eikä ole hajonnutkaan vaikka auto täys loskaa mutta kerta se on ensimmäinenkin kun jotain hajoaa.
RunWild81
Servojen muovi pakkauslaatikot ja nuppineulojen pakkauslootat on aika passeleita tähän hommaan. nuppineulakeissiin mahtuu esim vastari ja silikoonilla tiivistää saumat ja läpimenot.
sakke.
Viesti Kirjoittaja sakke. »
onnistusko suojatasähkot silikoonl? :P ku siäukko käy villin ku kaks noparii on hajonnu ku on saanu kosteutta..   :-\
Itse suojasin joskus traxxasin xl-5 noparin nimenomaan silikoonilla. Purkasin kuoret irti, saniteettisilikoonia reilusti joka paikkaan, ja kuoret takaisin. Silikoonia tuli joka aukosta kasatessa, eli pitäisi olla tarpeeksi...   ;D
Revoman
oon suojannut nopareita silikoonilla ja vaseliinilla. Isommat reijät silikoonilla ja sisälle nopariin vaseliinia täyteen.
Myös vastaanottimia on tullut vaseliinilla suojattua.
