Tekin Hotwire ohjelma
Eagle-no1
Kaikki ohjelman omistavat varmaankin jo päivittäneet uuteen versioon joka on ilmestynyt: Mar 5, 2012
223 Has the following changes and improvements:
Improved throttle increases smoothness and precise control.
Improved braking increases control and responsiveness.
Customization now available with user-adjustable throttle curves.
Load, Save and Transfer your custom driver specific ESC setup profiles!
"ClubSpec" Spec Mode indicated by led's 3 and 5 flashing. Same as version 212 and selectable on the ESC.
Big Event "LockOut" Spec Mode, locks the ESC into Spec Mode and cannot be changed without plugging back into a HotWire. Factory Reset does NOT turn LockOut mode off. LockOut Spec mode indicated by led's 3, 4 and 5 flashing.
Active Braking: For boosted Touring Car setups that need super strong brakes, you asked and we answered. You can now have the brakes 212 offered for touring car by turning Active Brake ON/OFF via the HotWire.
http://www.teamtekin.com/hotwire.html
