Nyt tämänkin voi laitta tänne kun näyttää noita ilmestyneen.
Samoin kotimainen maahantuoja EuroRC http://www.eurorc.com
Heidän nettikauppakin aukeaa jossain vaiheessa, ilmeisesti lähitulevaisuudessa.
Lontoonkieliset tekniset tiedot:
www.teamtekin.com/fx.html sivulta.
Controls: Forward/Brake/Reverse
ON Resistance: 0.0012 Ohms
Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor)
BEC: 6.0V/3.0A
Motor Limit: 13 Turn
Throttle Profiles: 7 choices on board
Reverse Type : 3 choices on board; none, delay, immediate
Reverse Strength: 11 steps on board
Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor
Dimensions: 1.1 x 0.80 x 0.40 " (28 x 20 x 10mm)
Drag Brake (11 steps)
Neutral Width (11 Steps)
Current Limiter (none, 10 steps)
Push Control- Anti Drag (11 steps)
FX, FXPro: Throttle Profiles (6 choices)
FX, FXPro: Brake Profiles (6 choices)
FX-R, FX-R Pro: Reverse Type (3 choices; none, delay, immediate)
FX-R, FX-R Pro: Reverse Strength (11 steps)
Voltage Cutoffs (none, 2S, 3S, Custom)
Additional Tuning via Tekin HotWire PC Interface (sold separately)
