Crawler luokkien säännöt kaudelle 2022
Tänne crawler luokkien säännöt ja keskustelut niistä.
Merry Christmas crawlers! 🎄
Today we have finally finished the 2022 Official WRCCA Rules:
https://docs.google.com/document/d/1rI- ... p=drivesdk
Changes:
Mini:
Addition
▪ 2.5.8 - Motor must be chassis mounted. Motor mount cannot be part of or directly coupled to an axle.
Performance Scale:
Changed rules
• 2.6.2.2 - Tires are limited to 4.8”/122mm maximum external diameter and a maximum width of 55mm from side wall to side wall. Tire size will be determined by advertised manufacturer specs. (Tires without available specs will be measured off the truck as mounted on the wheel laid flat).
• 2.6.2.3 - Siping, grooving, shaving and removal of the lugs from any kind of production tire is allowed as long as they meet rule 2.6.2.2 Only production tires are allowed that meet 2.6.2.2 rules. Internal tire modifications permitted are trimming and sanding of tires.
•2.6.2.4 - Original size of the tire must be maintained. Cut and shut, narrowing, reducing or increasing, of any kind, is not allowed. Tire carcass cannot be cut.
•2.6.2.5 - Production pin tires, even if they meet rule 2.6.2.2, are not allowed.
• 2.6.1.2 - Vehicles must run a minimum full body from the grill to the B-pillar. The grill can not be cut or modified. (Bodies without a grill must have full hood/bonnet). Wheel arches and headlights may be trimmed for clearance.
• 2.6.1.3 - Cab only configured rear chassis must have frame or bar work or tray (bare chassis and shock hops is not acceptable). Removal of the roof is allowed so long as roll gage/half interior is fitted.
Deleted rules
• 2.6.1.10 - All throttle electrics, motor and transmission are to be covered by the body/tray when viewed from above.
• 2.6.2.5 - Wheels/rims must be a minimum 1”/25mm wide at outer bead ring surface.
Re: Crawler luokkien säännöt kaudelle 2022
Kaudella 2022 SM-sarjassa sekä pohjoisen sarjassa muokataan hieman ajanottoa. Tästä lähdin ajetaan 6 minuutin maksimiajalla ilman ajanostoa. Tämä siksi koska sama päivitys tehtiin tuleviin PM ja EM kisoihin ajanoston hankaluuden takia.
Onkohan tämä oikea ketju kysäistä, mutta tuli tuossa pro:lla reenaillessa mieleen, et miten pakki dumataan pro autossa?
Tuossa omassa laitteessa ei drag brake pidä, niin melko usein tulee vastaan tilanteita, missä auton eturenkaat pyörivät eteenpäin ja takarenkaat taaksepäin auton valuessa alas kallion seinää.
Onko kyseinen skenaario pakki vai ei?
Aina kun pyörät liikkuu taaksepäin tuomitaan peruutus. Eli kyllä.
Zarizi Tech kirjoitti: Su 15.05.2022 23:01 Aina kun pyörät liikkuu taaksepäin tuomitaan peruutus. Eli kyllä.
Pakko tarkentaa vielä. Tarkoitathan liikkumisella pyörimistä?
Onko se tuomarista kiinni vai onko jotain yleistä ohjeistusta kuinka tarkkaan tuo tuomitaan?
Tyhmiä kysymyksiä varmasti kokeneemmille, mutta näin pro autolla aloittelevalle budjetti sähköillä se on ikävä kyllä ihan arkipäivää, että auton keula lähtee nousemaan ylös kalliota ja sit veto loppuukin takarenkaista, eturenkaat pyörii tyhjää ja auto valuu alas. 😅
NumeroKaksi kirjoitti: Ma 16.05.2022 11:44
Pyörimistä kyllä. Kyllä niistä vaan valitettavasti kuuluu pakki tuomita.
krajok
Viesti Kirjoittaja krajok »
Autoa voi liuattaa alas päin esim käännöllä tai renkaat sutissa voi mennä alas, eikä minun käsitykseni mukaan ole pakki virhe, pakki virhe tulee vasta kun rengas pyörii taakse päin
Zarizi Tech kirjoitti: Ma 16.05.2022 21:07 Pyörimistä kyllä. Kyllä niistä vaan valitettavasti kuuluu pakki tuomita.
Ei se ikävää ole, säännöt on kaikille samat. :)
Onko jotain yleistä linjavetoa pakin suhteen vai jokaisella tuomaroijalla/ajoryhmällä omansa? 1/4 kierros tai 1/2 kierros esim?
