Novak Goat Crawler brushless System, onko hyvä??
Mikki
Viesti Kirjoittaja Mikki »
Novak Goat Crawler brushless System olis ajatuksissa. Olisko hyvä AX10:iin ?
Tässä spexit:
FEATURES:   18.5 Turn Motor Features-
Designed for car applications that require precise movement control
and for vehicles that require super low speeds
Ideal for vehicles with separate transmissions like the Tamiya Clod
Buster
Sensor-based technology for lots of starting torque, low speed
driveability and low cogging for smooth acceleration and coasting
High strength rotor and larger, more rugged front bearing for extra
durability and long life
Aluminum ribbed end bells for additional cooling
Low resistance Direct-Solder Wiring Tabs for flexible soldering
options
ESC Features-
2 Driving Profiles, one for normal motor rotation and one for reverse
motor rotation
Built-in LiPo cutoff protection (can be activated in either throttle
profile)
Brushless throttle profiles feature Zero Reverse Delay and adjustable
drag brakes (or "hill" or "hold" brakes)
User-friendly program interface with four status LEDs
Fits in popular 1/10 scale electric R/C cars
Variable Throttle Step
One-Touch Set-Up
Radio priority circuitry
Water resistant case
Gold plated PCB Direct-solder wiring tabs
User-replaceable input harness
Thermal overload protection
Factory installed power capacitor
Power output for optional 6V accessory fan, not included (NOVC5648)
120 day warranty on both components
INCLUDES: Crawler Electronic Speed Control
18.5 Turn Sintered Crawler Motor, NOVC3419
SPECS:       Motor-
Number of Turns: 18.5
Design: Sensor-based
Input Voltage: 4-7 cells (1.2V/cell) or 2S LiPo cells
Watts: 119
KV (unloaded): 2,700 RPM/Volt
Motor Size: 2.08"L X 1.41"D (52.8mm x 35.8mm)
Shaft Diameter: .0125" (3.2mm)-accepts all existing pinion gears
Motor Weight: 6.73 oz. (191 grams)
Bearing: Oversized (1/2" x 3/16" Front, Standard Rear (3/8" x 1/8")
Magnet: One-piece multi-pole cylindrical high-strength sintered
Neodymium
Electronic Speed Control-
Input Voltage: 4-7 cells (1.2 VDC/cell) or 2S LiPo cells
Size: 1.54 x 1.18" (39 x 30mm)
Weight: 2.84 oz.(80.7g) with wires, 1.49 oz (42.2g) w/o wires
Throttle Programs: 2
Status LEDs: 4
BEC: Heavy-duty 6.0 volt/5.0 amp
On-Resistance: 0.0012 ohms (per each phase-3)
Rated and Braking Current: 120 amps
Voltage Cut-off: 6.25V (with LiPo cut-off circuitry enabled)
Discrete Steps: 1024 (512 forward, 512 brake/reverse)
Motor/Battery Wire: 14-Gauge Silicone
Viimeksi muokannut Mikki, To 15.05.2008 23:56. Yhteensä muokattu 1 kertaa.
jesi
Vs: Novak Goat Crawler brushless System, onko hyvä??
Viesti Kirjoittaja jesi »
Kyllä tuo hyvä on, voittaa alapään kontrollissa sensorittoman harjattoman 10-0.
Mutta MINUN mielestä tuo on hieman kallis siihen nähden mitä siinä saa.
Yleisin moottori, eli harjallinen Lathe vastaa tarpeita paremmin melkein millä asteikolla vaan.
Ja siitäkin voi tehdä päätelmiä, tällä foorumilla taitaa yhdessä autossa olla kyseinen paketti, autoja on aika paljon ja monella ei sinällään ole harrastaminen rahasta kiinni......
Divi
Viesti Kirjoittaja Divi »
Ja lathen kaveriksi kun tuuppaa MM niin on säätöjäkin vähintään riittävästi.
Mikki
No tulipa tilattua sitten tuo setti jokatapuksessa. Siis ei Suomesta, koska täällä sikakallis setti.
Millainen akku systeemi olis hyvä? Ajatuksis olis keulille kasattu paketti. Mut nii, mimmoset akut?
Viimeksi muokannut Mikki, Pe 16.05.2008 09:24. Yhteensä muokattu 1 kertaa.
Mikki
siis joo ei mitä savuja pihalle noparista. :o Kattokaas kun ole vähän kalkkis tän uuden akkutekniikan osalta... Niin siis juuri tuohon settiin sopivat akut? Jos jakais ne etuakselin päälle.
Divi
lienee järkevin 6 kappaletta NIMH kennoja. Akselille mahdollisimman alhaalle maavaraa rajoittamatta junou.
Mikki
Jees, täytyypi kattoo sopivat kennot. Meinasin jakaa etuakselille servon kummallekkin puolelle.
No laitampa tähän, että otin Eliten 1500 kennoja 6 kpl. Koitetaan niitä.
Viimeksi muokannut Mikki, La 17.05.2008 11:10. Yhteensä muokattu 1 kertaa.
Mikki
Nopari ja kone asennettu. Koko auton luonne muuttui täysin. :o Vääntöä ja tarkkuutta tuli pienimmille nopeuksille mukavasti. Tarvittaessa räjähtävää tehoa löytyy nyt. Ja ei tarvitse kuunnella sitä vinkunaa, mitä vanha nopari piti. Ja autohan oli siis AX-10 RTR.
Vastaankin alkuperäiseen kysymykseeni, että on hyvä. ;) Tosin kallis Suomesta ostettuna... :'(
Koheltaja
Novak on tehnyt Goatista 3S version joten hyvä nopari muuttui vieläkin paremman kun pääsee käyttämään 3S lipoja. Saattaa olla että laitetaan nykyinen Goat kiertoon ja laitetaan 3S tilalle ;)
Hedgehog
Re: Novak Goat Crawler brushless System, onko hyvä??
Viesti Kirjoittaja Hedgehog »
Mitäs "sika" kallis 3s lipoja kestävä kombo suomessa maksaa? Ja ken myy?
2010 Scale 6
2011 Sportman 5
TomiK
Viesti Kirjoittaja TomiK »
Hyvinhän tuo on Novak Goat 3S + 21.5T Ballistic -kombo pelittänyt LCC:ssa. Tilasin Liquidista.
RC Garagen kautta saanee tätäkin osaa?
