Tollanen tuli vastaan hobbypeoplen sivuilla: http://www.hobbypeople.com/shop/index.p ... s_id=15761
Kori näyttää aika pikkukakkosmaiselta mutta sekäs lienee ongelma ;)
Tämä näyttää ihan hyvin kulkevan että jos joku lähtee yrittää :D
Ja jos joku ei jaksa mennä hobbypeoplen sivuille:
sähköt
Accuadapter Lead Amp-Ta (1) 1-4399
NiCad Battery Sanyo 6 N C2.4 K (1) 1-4613
NiMH Mignon 1.2V AA 2500 mAh ba (8) 1-8005
Rookie Truck Controlle (1) 1-8407
Unicharger (1) 1-8500
Servo S 3150 Digita (1) 1-F1330
Attack ER 2/2/2 40 MH (1) 1-F2211
jotain sössöö
* Two-part aluminium channel-section frame, all holes drilled
* Channel-section frame swivel-link unit for increased angular travel
* Rigid-drive rear axle, reduction ratio 2.9 : 1
* Rigid-drive front axle, reduction ratio 2.9 : 1
* Braces, tie-rods and outriggers on both axles
* Aluminium steering servo mount, fits directly on front axle
* Four-wheel drive distributor gearbox with rigid drive, reduction ratio 3.14 : 1
* EF-76 II electric motor with 12-tooth M0.5 drive pinion
* Primary motor gearbox, reduction ratio 5.5 : 1
* Central aluminium mounting for electric motor and distributor gearbox
* Articulated joint shafts to front and rear axles
* Fore-and-aft coil spring shock absorbers with angular actuator system
* 28 ballraces
* Newly developed profiled 100 mm &hibar; Truck Trial tyres
* Plastic Panther wheels
* Small hardware items such as bodywork stand-offs, split pins etc.
* AMP connector for drive batteries with TAM socket
* Clear, multi-part polycarbonate bodywork
* Multi-colour decal sheet with window masks
* Multi-lingual building instructions with assembly drawings
tosta vielä
Length: 420 mm
Width: 185 mm
Weight: 2000 g
Height: 240 mm
Scale: 1:12
Wheelbase: 280 mm
Length: 420 mm
Catalog page: http://data.robbe-online.net/robbe_pdf/ ... 1-3333.pdf
Instructions: http://data.robbe-online.net/robbe_pdf/ ... 1-3333.pdf
Video clip: http://www.robbe.com/video.php/en_play- ... 1-3333.wmv
;D
Mountaineer 4X4 Trial Truck
historia
Viimeksi muokannut historia, Pe 08.02.2008 16:35. Yhteensä muokattu 1 kertaa.
RunWild81
Vs: Mountaineer 4X4 Trial Truck
hyvin toi on näyttänyt menevän noissa nahkahousujen trial kisoissa. Youtubessa on kohtuu paljon videoita niistä. Ja ihan vakionakin kohtuu näppärä laite.
