Mikä ilmeisesti kestäisi jopa 3s lipon jännitteen..
Specification:
Dead band: 0.0008 ms (Default)
Control System: +Pulse Width Control
Working frequence: 1520μs / 333hz
(RX) Required Pulse: 3.5 ~7.4 Volt Peak to Peak Square Wave
Operating Voltage: 8.4 ~12.0 V DC Volts
Operating Temperature Range: -10 to + 60 Degree C
Operating Speed (8.4V): 0.180 sec/60° degrees at no load
Operating Speed (12V): 0.130 sec/60° degrees at no load
Stall Torque (8.4V): 26.90 kg.cm (373.6 oz/in)
Stall Torque (12V): 38.40 kg.cm (533.3 oz/in)
360° Modifiable: NO
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Programmable: NO
Connector Wire Length: 15.0 cm (5.9 in)
Dimensions: 40X20X45 mm (1.57x0.97x1.77 in)
Weight: 78.5g (2.77 oz)
http://www.hobbycity.com/hobbycity/stor ... 0sec_/_79g
Että tualla alkaisi jo rawlerin kumekset kääntymään.. ;D
