Kai-modosu
2.2s (shafty)
macman
Re: #6 Kai-modosu
Viesti Kirjoittaja macman »
Huikeita kuvia! Upea "fairy tail" tunnelma   ;)
RaumRC
Re: #6 Kai-modosu
[quote="Hadesbear"]
Hienosti näytti etenevän ja lookki on kohillaan! Odotettavissa mielenkiintoinen ensvklopun kisa ja koko kausi!
Hienoa, että joku jaksaa ja kykenee kehittämään maailmantahtiin laitteita  8)
Todellakin. Ensi viikonlopun kisa tulee olemaan kyllä tosi mielenkiintoinen. Ajotyyli tuolla autolla on aivan erilainen mitä normaalilla shaftyllä. Katotaan miten käy.
[quote="macman"]
Kyllä. Kameran kanssa opettelua vielä, mutta tarkoitus olisi räpsiä enemmänkin tulevana kesänä kuvia.  ;)
Today I had time to finish body modifications and start preparing this to it's debut comp. Kuva
Had to cut the vertical bit from the nose off, so it'll clear servo and battery.
Had to carve a little corner to the hood. Now the body is fully compressed.
Next and the biggest issue. That's all that my rear end does when you are pushing it down. Vital thing to reach the 12,5" wb in steep climbs. Upper link mount is really high and I can't move the body upper than that. Hmmm...
There is the trouble maker.
Cut off the Krawler Konceptz logo?
I wanna see Michelle's face right now. Kuva
Well?
We have a toilet cover right there! KuvaKuva
Little room for shocks to do their work as well.
You see now? Kuva
Toilet lid needs a limiter, so it won't cut off too easily, when trying to get the rig up from a roll over.
Am I genius or what?! KuvaKuva
After I finished with the body I continued by thread locking the rear axle screws.
Next week I'll have to do the same treat for the front axle.
I had messed with the 40wt shock oil the whole day, so I changed the oils to this rig as well. Kuva
The lexan motor cover wasn't flexible enough so I found a BWD motor cover to do the job instead.
Allthough there is already a giant crack in this as well. Gotta contact winner to order a Custom Fiber cover. Kuva
Little more cutting under RC4WD logo and I was done for the day. I think the body is ready for the comp. Rest of the rig still needs finishing touches.
Re: #6 Kai-modosu
Hienoa kekseliäisyyttä - poistamatta arvokasta logoa - vessanpytty"läppä"   :D
On kyllä jännä seurata tätä ens vklopun kisassa, kun ekat OIKEAT ajot tulee eteen, mielenkiintoista!
Samuli
Re: #6 Kai-modosu
Viesti Kirjoittaja Samuli »
Mites vessanpytyn kansi tarttuu maahan/haittaa pystyyn ajamista kun auto on katollaan ja akseli painaa sen ulos???
Re: #6 Kai-modosu
[quote="Samuli"]
Varmastihan se tuo oman haasteensa siihen. Koitetaan nyt alkuun kuitenkin pitää vehkeet kumeilla.  :D
Re: #6 Kai-modosu
Onko tuosta korkeasta korista (ohjaamosta) enemmän hyötyä kaadon jälkeen renkaille saamisessa....kuin painopisteen noususta haittaa?
Re: #6 Kai-modosu
[quote="kenne"]
Rutkasti. Ainakin näin väittäisin. Tuon painoisessa autossa ei myöskään niin paljoa tunnu korin ohjaamon korkea painopiste.  ;)
Still finishing touches to do before the comp.
I went the whole front axle thru and put locktite to srews.
A little rear shock limiting.
Not much, but enough to make a huge difference. Kuva
Everything clears with flying colours! Kuva
Set also my wb and start on gluing the titanium link sliders.
All glued. Kuva
I put a little amount of grease to make the front bevels to run smoother. We'll see how well that went. Kuva
Just saw, that my tires are in finnish customs and with a good luck they'll be here on thursday. Kuva Tomorrow, I'll get on with the deans soldering on the batteries.
macman
Re: #6 Kai-modosu
Eikä se korin nosto haittaa paljon kevyemmässä autossakaan. Painoikohan toi kori jonkun 30-40 grammaa? Sen muistan että oli huomattavan kevyt esim.
vanhaan xr10 koriin verrattuna.
RaumRC
Re: #6 Kai-modosu
[quote="macman"]
Juu, taitaa olla kevyimmästä päästä mitä markkinoilta saa. Kohtuu ohutta lexania käytetty.
Re: #6 Kai-modosu
Today I finished the rig for it's debut comp!
Tightent screws and checked that everything is working. Too bad the tires didn't make it to this comp. I'll have to change the tires between this and the pro.
RTR weight for the comp. Got my aluscrews today, but I'll put them on to the next comp then. Kuva
All set. My goal is to have at least one good course and keep the thing alive whole comp. New rig, you'll never know what'll brake down. Kuva
Bunker Indoor comp with a record participation! Kuva
I do hope everything will go as planned tomorrow. I'll update on sunday with pics and video. Kuva
Re: #6 Kai-modosu
Debut comp behind in the Bunker!
Bunker offers the only possibility to drive indoors in whole Finland.
Starting the comp.
First course was a real disaster for me. Got to gate seven and then runned out of points. Voodoo's weren't gripping enough on that concrete floor.
The course was pretty tough as well.
Best points were +19 and I got +26, so no serious harm done there.
Relly making the way tough with my line descisions. Kuva
Course two on the way!
I was the last one to drive it. Nobody had finished it before me.
Trying to think a different approach to the next gate.
Sliding it down to bonus.
Progress!! Kuva
Then next gates were relatively easy.
Suspension in this thing seems to be spot on! Kuva
And the new Nexus motor is giving me plenty enough wheelspeed to jump over places like this. Kuva
Going for the last three gates.
Eventually I made this course to the end! Kuva
https://www.youtube.com/watch?feature=p ... IW3eipigdY
Here is course number three. This course went really well except for one bonus marker. Kuva Here you can see some of the advantages of this rig. Breakovers were childs play to it. Kuva
After four courses of competing Kai-modosu was crowned to first spot of the day! Kuva
Felt damn good to take that trophy home. Few months of intense building has come to it's end. Now I can start practicing! Kuva Too bad I won't be able to take it to the Worlds on september, but it'll be a heck of a pain in the ass in Europe for sure! Kuva
macman
Re: #6 Kai-modosu
Pääsin tänään ajamaan "pikkupossua" ja aika vinkee oli ajaa. Hieman erillainen kuin perus shaftyt. Tavallaan aika helppo ajaa tosin hypyttämällä kääntäminen ei onnnistunut . Aika raskaan oloinen ajaa, mutta samalla tietysti todella rauhallinen ja ennalta arvattava. Kivikko radalla ei paljon tasssuja nostellut.   Taitaa olla julmaa jälkeä tulossa tulevalla kaudella   :(
RaumRC
Re: #6 Kai-modosu
[quote="macman"]
Kyllä se tosiaan hyvin etenee. Tuolla kivikossa taitaa parhaiten tulla auton hyödyt esiin. On aika kaivaa sotakirveet esiin, kausi on alkamassa!  ::)
Good training weekend behind! Kuva
Got all of my rigs in the testing line!
Shafty was epic outdoors! Even better than I thought it will be. Kuva So easy to drive, extremely predictable and stable.
After two days and ten batteries, nothing, I repeat nothing came loose or broke. Kuva Rig seems to be pretty well dialed in. I can now be pround of my work so far. Kuva
Tests will continue on few more weeks. After that, we are really starting to compete. Kuva
Re: #6 Kai-modosu
A little updating continues...
It's diet time! Kuva
I already had al screws on the chassis, but I wanted to put them everywhere possible. Still not confident enough to replace some screws which are constantly under a lot off stress.
At least the color is now right! Kuva
Not much of a saving, but saving it is. Kuva
5g off from previous setup.
The weather wasn't good enough to have training this weekend, but I'll try to get it out next weekend. Kuva
Re: #6 Kai-modosu
To get the right feeling in terms of driving this truck I've done lot's of training recently. Kuva
Can't belive that I'm out training in March with a T-shirt.. Kuva
That has to mean cold summer. Kuva Kuva
After some 20'ish batteries the only thing that broke was one rod end. That's quality stuff right there! Kuva
Some closer looks of the skins in sunshine.
#motto
Who will recodnize the rigs in his eyes? Kuva
Another training day on a different spot.
Oh, almost forgot. One aluminium screw got a new bending. Kuva
And yes it's easy to drive this thing on it's wheels cause of the Xcitier body and BROOD NEXUS POWA!! Kuva
Only the drag link for steering is on todo list for now. So it's looking good for next weekends comp. Kuva Maybe some more training before it?
Re: #6 Kai-modosu
Next comp is behind the corner!
Last screw tightening and repairing done. Kuva
It's ready for the first comp outdoors of it's career. Kuva Should be a good one. I have enjoyed to drive this thing outdoors already.
With more than ten rigs on the line, it's not gonna be easy to continue from the indoor comp result. But I'll do my best. Just hoping for a good sunny day! Kuva
Re: #6 Kai-modosu
Anyways, the first outdoor comp is now driven with this rig.
Total of fourteen shafty rigs were registered to go. Kuva And this was "only" a team event. Kuva
My shafty was ready and eager for the challenges that lied ahead.
In the morning it was still raining, but it stopped during the comp and we got to drive on dry rocks. Kuva
Ready to go on the final course.
Really happy about the overall performance of this thing. Kuva
Result of the day was only 12 reverses in total. And I managed to drive all of the bonuses. This thing sure is a performer! Kuva
This was a really slippery rock, but no problem for Kai-modosu!
Another bonus. Kuva
And another. First I tried this from the top.
Gate eight - progress.
Next approach to the bonus from down.
After one reverse, I managed to clear it. Kuva
Extremely happy about the day. Kuva
https://www.youtube.com/watch?feature=p ... JxF0yUtCTI
Here is course number three on video. I was the only one to clear all the bonuses in this one. Kuva That thing just goes like a thought.
These surely are objective performances. I hope I can continue on training and keeping this level of driving onwards.
Next comp will be after two and a half weeks. Until that, I should go and do some training. Kuva
Re: #6 Kai-modosu
A little update before the next comp.
Piece of carbon fiber from Custom Fiber! Kuva
Old delrin motor saver straight into trash can.
Stunning work with this Troy! Thanks! Kuva
Kai-modosu is ready for another comp. It's gonna be huge attendance again. Kuva
We'll have this comp in a new comp ground. Should be cool place to crawl.
I'm more than ready for it. Bring it on! Kuva
Re: #6 Kai-modosu
Onnittelut voitosta, hienosti ajettu, vaikkakin tiukkaa kisaa! Kenties tämä on hairahdus, kenties jatkossakin tiukkaa kisaa?
Pääasia: tätä oli viihdyttävä seurata!   8)
Re: #6 Kai-modosu
[quote="Hadesbear"]
Kiitokset!
Third comp with this rig is done. Opponents are getting closer comp by comp. Kuva
In the first course I hit a bonus gate by coming with wrong line into it.
These photos are from the second course.
Bonusbonusbonus!
Easy gates this time. Kuva
Then I came to gate five. A real pain in the ass.
I felt like I needed more weight to the front. There was just no line for me this time...
So I rode it over and continued to make it to the finish.
Sixth gate was in steep downhill sideways. Many guys took a gate in here.
And I was the only one to clear this bonus gate. Kuva
And one final easy bonus!
Off to the finishing gate.
Made it to finish with second best score.
https://www.youtube.com/watch?feature=p ... Y-O68N-8qE
Third course was easy and I got full -50 point score from there. As we headed out to this final course, I was two points behind the leader. After all I managed to keep my head cool and took the victory with that two points. Kuva
Babyface ftw! Kuva
Tight comp this. Makes me wonder what the future brings. Only two comps before the Nordics in Norway. Kuva
Training, training, training, training, training....
....ning. Kuva
