Kai-modosu
2.2s (shafty)
Re: #6 Kai-modosu
[quote="SlidSlide"]
Kyllä näissä Samun autoissa on upeat kopat. Mitäänsanomattomasta koristakin tulee komea, kun vähän panostaa skinzeihin 8) .
Kyllä ite oon tosi tyytyväinen. Asiakaspalvelu Krawler Konceptzilla on parasta mitä voi löytää. Lähes kaikki toteutukset skineihin on mahdollista. Ei voi kun suositella. 95$ maksoi setti tähän koriin. Ei ole siis hinnankaan kiroissa ottaen huomioon, että niihin saa mitä vaan.  ;)
My attention today was only to finish the body painting. Got a little carried away maybe?
Started with drilling the tubes for Dlux shafts.
Measured the shaft and then with the right tools started to drilling. Thanks to Arttu who did the hard part. Kuva
Little bit nervous with the set of tools we had. Kuva
Yikess... Kuva
Perfect result for drilling these tubes. Thank god. Kuva
Assembled the shafts and Dlux knuckles to my front axle and took it on scale. It's gonna be one heavy ass axle! KuvaKuva
Rear axle is ready for some linkage work!
Front axle attached.
All of Dlux goodies are perfect matches for each other. Kuva
Upped links made! I took apart one super chassis and got some links from there. For example the steering link, which happened to be a perfect match. Kuva
Got the front uppers nearly from first try to their spot. I just have to do a little more tuning to them. Not much at all. Kuva
It's really close to be the setup for this chassis.
Rear uppers were much easier to put there. Also got some pretty good clocking done to it. Kuva
Testing how will it look like before the body goes to painting.
Saweeeet! Kuva
Here's a side view of the links.
Rear shocks to little bit wider. I'm getting there...
No contact whatsoever.
The steering doesn't look too bad. Kuva
Front setup is near as I said, but little tuning still needed.
Next thing would probably be to attach the drive shaft "transfer box".
Before that though, let's start the painting.
This time I'll take it easy. Don't wanna screw up that piece of magnificence. Kuva
Meanwhile it's drying, I'll get back into the chassis.
Istalled it with two screws - one from the side and one from below the chassis.
This is my front drive shaft. I had to make it really tiny. Total lenght 110mm. Kuva
And the drive shaft sits in really high! Kuva
Rear drive shaft and recently rotated Dlux rear lower links. Thanks for the advice in other topic Erik! Kuva
It's starting to look really nice!
Weight at the moment. Still missing electronics, tires, foams and body for example. It's gonna be 2kg beast I think. Kuva
Yes, got a little carried away from painting the body... Kuva
Tomorrow I'll finish that body then. Kuva
Re: #6 Kai-modosu
Finished the body today!
Few more labels with black and it was done!
Way better result, than with my previous XCitier body painting. Kuva
Time to take the covering label off.
Ohhhhhhh......! Kuva
Suddenly the colors came to live! Kuva
Cutted the extra bit from sides.
Sideview.
That looks ridiculously good!! Kuva
Hood and the rivals glitching in his eyes! Kuva
Tale of revenge.
Some golden sponsors and THE flag. Kuva
Once again huuuugee and massive thanks to Michelle in Krawler Konceptz! This is my alltime favorite of your designs! KuvaKuvaKuva
Now I'll prepare the other rigs for the Arctic Special comp on saturday. I'll get this running in the Bunker competition on february! Kuva Stay tuned next week for more building!
Re: #6 Kai-modosu
Täytyy sanoa, että tyylikäs se on! Kyl jää paukkupulloviritykset toiseks, kun tälläsiä näkee!   8)
Re: #6 Kai-modosu
[quote="Hadesbear"]
Jep, samaa mieltä!
Yesterday did some more stuff to get this thing going at some point.
Good dark german beer and some battery soldering. Bad complination? Kuva
Half of them done.
Then it was time to test out, if I would be able to adjust these in my laptop. These are from my pro from the spring. They gave me some smoke, so I have left them waiting ever since.
The only result from that batch. BEC is working, both of the BR-Minies are gone... Kuva I'll just have to find me a BR-Mini from somewhere.
Three of four Team Zarizi Tech rigs are in the comp tomorrow. Almost finished with this one, but didn't have the time on my side. Next comp then. Kuva
Re: #6 Kai-modosu
Time to continue this a little bit.
Stole the tires from my pro to test out wideness and stuff.
Also got some goodies from Sweden again! Kuva
CF battery and servo mount.
Still great products! Kuva
Next attaching Gunnar body mounts and THE body! Kuva
Ohhh yes! Then a little cutting to make it flex to the max. Kuva
So far I had to cut from front and rear only. Kuva
Still plenty of room for suspension and tires.
Weight without electronics. Kuva
Oh wait, I have the servo to attach there! Kuva
Making the front end a bit wider. The tires were scrubbing to the lower links at full steer.
Now it's good. Front 270mm and rear 250mm. Kuva
Now it has the room to turn. Kuva
I'll probably let these tires be under this rig and get the new set for my pro. Kuva
Bent lower rod ends to my front shocks. Kuva
And little bit of shaving to make the upper links clear the gearbox in every single position.
Looks ok!
I still have to open the lower rod ends a bit to get to 12,5" wb.
Narrowed the shock attaching points to avoid them touching the body.
I also tried to get my Stubby to the front axle, but it is a no go. I had a feeling it might be too big, so now the new Nexus motor is on it's way to this thingy. Kuva
I also have ordered Holmes Hobbies BR-Mini for this. Should be here any day now. Kuva Soon I have all of the parts. KuvaKuva
Not far from being 3/3 driveable! Kuva
Re: #6 Kai-modosu
Got new motors for the pro today and was able to test in on shafty.
It fits. Kuva Now I just have to wait for the shafty motor to arrive as well. Kuva
Re: #6 Kai-modosu
Something arrived...
Brood related?
Indeed! Kuva Team Brood Racing Nexus 35T with regular can.
It's a fit as predicted before. Kuva
Here you can see how darn close the bevel gear is to the can. There's now way, that Stubby would fit in there. Kuva
Rest of my electronics are in finnish customs and I should get them here in time. I want this to be moving on sunday! Kuva
Re: #6 Kai-modosu
Sad to notice today, that the stuff for this rig didn't make it here today. I think they'll be here on monday. Kuva
I decided to continue with the things I had here.
Protection for the bevel gears in the axles.
Rear axle cover mounted.
All about protection. Kuva
I also changed the spring limiters to plastic ones.
Front cover done as well. Kuva
I'll continue when the parts arrive.
Re: #6 Kai-modosu
Still a lots of small stuff to do besides the electronics, so let's get on with it.
Had to shave some material off from the axle to get 100% of the suspension working.
The driver front lower link was touching the axle.
Not anymore. Kuva
Progress! Kuva
I put my motor in the axle and made motor cover from lexan. I will get a cf one at some point.
It'll protect the new motor on it's first comp.
It's there and I can already notice, that the front axle is reaaaally heavy. Kuva
Drag link next. I'll order a titanium one soon as well.
I'm really hoping that the stuff I need will come tomorrow. I cannot wait to get it going!! Kuva
Re: #6 Kai-modosu
Today was the time to finish this dude! I wan't it to run! Kuva
Holme Hobbies BR-Mini with CC BEC and new pinions for the rig. All I need to finish!
Soldering time!
God I hate this stuff! Kuva Luckily I bought myself a new soldering iron. Way better to work with it now.
ESC and BEC ready for some testing!
Oh wait, not yet! The deans connector had to be soldered as well. Kuva
Throwing in my new pinion.
Had to unattach the lower link and shock to solder motor wires.
With that done, we're getting closer! Kuva
Throw in the receiver and battery and it's ready for it!
Couldn't find a better place for ESC and BEC.
Tested it without connecting the BEC first to bind and making adjustments for ESC. All went well. Then I connected the BEC wire to receiver. After giant spark fronm the deans connectors and a huuuuuge amount of smoke coming from the ESC I checked the wires. Kuva DAAAAARN, I forgot to take red wire off from ESC wire which goes to receiver.
Job well done idiot!! Kuva
Well fortunately my brother had a spare Castle Creations Mico Sidewinder and I had a spare CC BEC. Time to get soldering again. Kuva
BEC new from package.
ESC soldered, time to adjust it to the radio.
Job done. Electronic pack version 2 of the day. Kuva (Good practise this btw...)
With that done, I remembered to move the red wire this time. Everything is now working. Thank god! Kuva
Tires attached. Kuva
All seems to be there. Time to test it out!
Well first it would be better to attach the electronic pack with zip ties. Kuva
Hmmm.... Still missing something...
THE lid! Kuva
Fantastic training ground is yelling at me!
https://www.youtube.com/watch?feature=p ... i9JQz9R_pQ
First drive with this thing! Oh dear lord the sound of that thing is awful! Kuva Kuva Josh was right about that. Kuva It goes pretty good and nothing burned or came loose. Kuva
I'm happy with it so far. Kuva
Attaching the electronics better for the indoor comp next weekend.
Suspension still clears. Kuva
Would be ready for some more testing if I find some dry rocks during the weekend.
Almost forgot to put the motor cover back on. Kuva Eddie will be furious if he sees a crack in that Nexus can. Kuva Kuva
God almighty!! It's light as a leaf! Kuva I'm stunned if that reading. In pounds that's like 0.0003. Kuva
Good day behind in the garage. Will continue on working and fine tuning it during the next week! Kuva
Re: #6 Kai-modosu
Vihdoinkin!   :) On se aikamoinen tekele ja vain aika näyttää erot "normi" shaftyjen ja tämän välillä.
Hienoa kuitenkin, että suomessakin uudenajan shafty. Kaudella 2016 nämä ovat ainoita   ;)
Innolla odotellaan, miten KAI moukaroi lahden radat historiaan   ;D
macman
Re: #6 Kai-modosu
Viesti Kirjoittaja macman »
Vai äänekäs pikku possu   ;D
Onhan tuo jänskää nähdä miten tuo oikeasti toimii ?
Hadesbear kirjoitti: Kaudella 2016 nämä ovat ainoita   ;)
Miten oikeassa saatatkaan ollakaan mikäli kehitys jatkuu tuohon suuntaan kuka enää jaksaa ajaa shaftyä ?   :(
RaumRC
Re: #6 Kai-modosu
macman kirjoitti: Miten oikeassa saatatkaan ollakaan mikäli kehitys jatkuu tuohon suuntaan kuka enää jaksaa ajaa shaftyä ?   :(
Näin se menee. Crawling tappaa itse itsensä, kun joka luokassa autot maksavat kohta +1000e.
Takavetokrossia pääsee harrastamaan noin 300e vehkeillä.
Re: #6 Kai-modosu
[quote="macman"]
[quote="Hadesbear"]
Katsoitteko ollenkaan videota? Eihän tuo eteneminen vakuuta kuin Nikkoihin tottuneet ;).
Re: #6 Kai-modosu
Tomy kirjoitti:
Älkää nyt immiset vetäkö ranteita auki, vaikka onkin perjantai 13 päivä   ;D
Ollaanpas sitä niin masentuneita. Hieman taisteluhenkeä tai jossei sitä ole, niin aika rc-sykiartille!
macman
Re: #6 Kai-modosu
You missed the point! Tämä laji kaipaisi jonkin sortin "vakio" luokkaa mihin olisi helpompi ja halvempi tulla sisään.
Shafty valuu tästä koko ajan kauemmaksi   :( Noin kolmella sadalla -neljällä sadalla pitäisi jo saada auto millä voisi
ajaa muita vastaan kilpaa. Ja tämä pitäisi mielellään pystyä ostamaan kaupasta lähes valmiina.
Anteeksi Samu O.T
Kallioilla sitten vasta oikeasti nähdään miten" pikku possu" kiipeää kallioita kuski on ainakin huippuluokkaa !
RaumRC
Re: #6 Kai-modosu
[quote="macman"]
Anteeksi Samu O.T
Spora (shafty) alun perin oli aloittelijaystävällinen luokka, jossa on hyvä harjoitella pro-luokkaa varten :). Ellei auton profiilia rajoiteta säännöin, niin kehityksen ja rahan tuoma ylivoima on aina läsnä. Niin se vain menee. Sorry OT.
R1pp3r T
Re: #6 Kai-modosu
Viesti Kirjoittaja R1pp3r T »
ensinnä anteeks ZT tämä ot joka on mieluusti viimeinen tässä topiikissa, tällä kiistelylle voisi joku perustaa oman topikin, mutta näin tämä nyt vain on mennyt joka luokassa iän kaiken.. kun aloin crawlereita katsomaan niin itseä kiehtoi moa luokka joka siihen aikaan oli lähes ainoastaan clod akseleista tehty.. kaikki luokat etenee sitä mukaa mitä harrastajat saa innovaatioita mitä ei ole sääntömuutoksella pois luettu.. spora luokka tuli juuri sen takia mikäli oon oikeen ymmärtäny.. ikäväähän tää on että homma menee siihen et täytyy lykätä rahaa hemmetisti että pärjää mutta vaihtoehtoina on ne että aletaan joko lykkään sääntöjä pirusti tiukemmiks taikka aletaan tekeen uusia alaluokkia, joista ei loppujen lopuks oo kellekään hyötyä kun harrastajia muutenkin on suhteellisen vähän.
Mutta mä tykkään tosta ZT:n tekeleestä ihan pirusti!! kiva nähdä jotain freesii.
Re: #6 Kai-modosu
First time outdoors today! Kuva
We found a place where there was still some rocks, which weren't covered in snow.
Me and my brother drove there few batteries.
Everything was working and nothing broke during the two batteries I ran.
This is a really beatiful spot to drive on in summer. We will be comping there on august. Kuva
Steering seems to be way better, than in my old shafty. Kuva
That body looks even more amazing outdoors! Kuva
Wallpaper material! Kuva
I noticed that the upper link mounts are touching the body while the chassis goes from up to down. I don't wanna screw the body, but I may have come with a solution to that. On the next update you'll see. Kuva
Kai-modosu has been set free. There's no coming back from that. Kuva
Re: #6 Kai-modosu
Hienosti näytti etenevän ja lookki on kohillaan! Odotettavissa mielenkiintoinen ensvklopun kisa ja koko kausi!
Hienoa, että joku jaksaa ja kykenee kehittämään maailmantahtiin laitteita   8)
