Bagdaröök
Re: #2 Bagdaröök
On last weekend, I was able to get the super running. Finally! Kuva
First things first. Let's put clothes on before going outdoors, shall we. Kuva
That's the coolest stuff on the planet! Kuva
More skins. Kuva
Hood attached.
Clothes on! Kuva
On a tough gate this is my view! Kuva
God, I have to get CF motor savers. Kuva
Really happy to see all of the trio driveable and looking like ready! Kuva
RFOT test day can begin! Kuva
Symphony of black and orange right there! Kuva
I honestly think this is the best desing by Michelle so far. Nothing compares to this. Kuva
She is ready for hot summer! Kuva
I can't thank enough Michelle and Rob in Krawler Konceptz. Skins are 80% of rigs looks and I'm more than happy of all of mine. Kuva
Then comes the driving bit.
https://www.youtube.com/watch?feature=p ... sPiXWjZHUk
Watch this all the way to the end. Bounty line for supers is the dessert. Kuva
I have never driven anything quite this special before. This thing is dialed in straight from the work bench! Kuva It keeps amazing me time after time and that steering is something, I've never seen in super. Those E.Y. Designs Voodoos are just the right height for it. Jeez I'm excited to do even more training! Kuva Too bad I broke a bearing from the rear axle at the end. I haven't opened the axle yet, but I'm confident it's just a bearing and the gears are still in order. I'll put it back on the rocks very soon. Kuva
DravTech Super SuDu seems to be one hell of a chassis too! Kuva Great work Tobias!! Kuva
Re: #2 Bagdaröök
Anyhow...
I heard some bad noises from the rear axle during training.
Let's get it down brothas!! Kuva
Hmmm.. yeah. Final gear doesn't look very promising. Allthought the bearings were in perfect shape. Kuva
New idler- and final gear.
Would this make it more silent?
Sure it did! KuvaKuva
Back to the shelf waiting for more training. Kuva
Re: #2 Bagdaröök
Time for a small update.
Been driving few packs lately. Kuva
Training in a pro course.
The ground clearance seems to be an issue here and there, but no more that I used to have with the Superjuice.
I've driven few batteries with it now and only broke a steering arm. Seems to be quite tough little buddy. Kuva
Fully compressed in action. Kuva
Still most of the time my constrantration goes to my radio. But I'm sure it'll get easier as time goes. Kuva
Pins seems to have an excellent grip nearly every spot. Kuva
On the other day I was training in a diffrent spot. Much more grippier and more sharp edges here. And it still goes like a beast. Kuva
I've managed to keep it on it's wheels quite well. Kuva
Next week I'll finish building it for now. Gotta measure the wb and assemble the links so it'll be somewhere near 17,5". Also I'll have to glue the sliders and put the electronics behind the front motor. Then it's good to go for more practice. Kuva
Re: #2 Bagdaröök
Time to finish this rig before doin more training! Kuva
I'll start by looking inside of the front axle.
I also found a way to use the Dlux front uppers. By turning this thing around. Kuva
While opening the gearbox I found out that my bearing from the end of the final gear is in three million pieces. Kuva Good thing I opened this now.
VP upper link mount turned around and the bearing problem solved.
Next job is to measure that the wheelbase is same in both sides.
Dlux titanium uppers attached. Kuva
Perrfecto! Kuva
Turns out that the links were just the right size. I'll have to use my head to make this thing work. Kuva
Wheelbase is now the same on both sides. Just under 17,5".
A while back Yzik asked me a side pics without wheels. Here they are.
Rear driver side.
Front driver side.
Rear passenger side.
Front passenger side.
Also got a new electronics mount behind the front motor from Dravpnir. Kuva
Attached. This is a great invention! Kuva
It's a perfect fit in there! Kuva
The electronics stuffed in there.
There will be just enough room for them.
Nearly ready RTR weight reading. Kuva
The next day I started with soldering the electronics.
Will make some wires shorter and some longer.
Rear wiring and assembling done.
Front done now as well. Kuva
Looks like a mess, but they are well organized there. Kuva
Pic from below.
I have been waiting for this moment a long time. It's finally ready!! KuvaKuvaKuvaKuva
And then I forgot that I have to glue the lower link sliders. In this pic it's done as well! Kuva
Final RTR weight reading. Kuva
All of my rigs are now ready for tomorrows comp day. For super it'll be just training, but this year I at least do that. Kuva
What a feeling after a long winter to finally have them all ready. Kuva It's been a crazy ride. Now I'll constantrate on driving. Kuva
Re: #2 Bagdaröök
It is a pleasure to drive this thing. Even more with MT-4 and rear steer on the lever. After getting used to that, it all goes like a dance. Kuva
Not really too much practising last saturday. Got the time for running one course after pro class had did it. Kuva
I was thrilled to show everyone the newcomer. Kuva
It has to be the most attacking rig I've ever had in terms of the looks. Kuva
There's still so much to learn from this rig. Will have to do a lot's of driving before the big comps. Kuva
That upper gate I hit by an accident. Not paying enough attention. Kuva
And that ground clearance. KuvaKuva
Suspension seems to be on "the" spot right now.
Just enough flex, so it's easy to control. Kuva
https://www.youtube.com/watch?feature=p ... XDhYLM9ggQ
And here it is on video!
Everything works flawless and I'm ready to do more driving as the weather is improving here. Kuva
Re: #2 Bagdaröök
Time for final update for the rig.
Update pack arrived.
Pauli4x4 Designs 3D printed hex hubs. A little bit narrower than the VP ones. Kuva
It's there and the colour is correct! Kuva
Turns out I need wider ones. It's not clearing my knuckleweight holders. Kuva I'll order a new set.
Finally I can get rid of the awful white motor guards. Some Custom Fiber CF awesomeness. Kuva
No more color mismatches. Kuva
Old front lexan motor guard. Kuva
YES! I'm super happy of all the components in this rig. Kuva
Some RC4WD upper link spacers to the chassis. Great product this. Kuva
Got balance?
Went out for a battery a while ago.
Some training before my hands got too cold to drive. Kuva
Tomorrow we'll have the fourth comp of the year. I'll try to get some training with this as well. Kuva
Pauli
Re: #2 Bagdaröök
Viesti Kirjoittaja Pauli »
Pitäiskö pikku spacerit tehdä vaan, niin ei tarvis kokonaan uusia napoja? Ei varmaan montaa milliä tarvis olla?
Re: #2 Bagdaröök
[quote="Pauli"]
Kyllä sekin kävi mielessä. Tosiaan puhutaan ihan parista-kolmesta millistä.
Re: #2 Bagdaröök
Did some more training yesterday.
With 2.2 courses the most difficult thing is the gate wideness. Rig barely fits in there and that makes it hard.
At least with this sort of training, I get a lot of shaprness in my driving.
With the rear steer in the lever, rig feels unbeliveably good to drive.
This time nothing broke either! Kuva
Only thing I found out, is that I don't have enough time to drive with this during our comp days. I'll have to go and do some super training days. Kuva
And still I haven't got a lot I would change currently.
With the rig being so light, it's sometimes hard to predict it's acting.
But that is what the training is for. Kuva
Tried this bonus, but it was impossible for me without gate. The front tires couldn't grab the top.
I'm beginning to fell comfortable with the rear steer, from now on I can fully train myself to know where it lifts a tire etc...
Still not regretting for making another super. Kuva
Can't wait for the Nordics in june. Kuva
https://www.youtube.com/watch?feature=p ... tsuxlsuWTw
Here's a small video from the training. Kuva
Re: #2 Bagdaröök
Nothing to report here!
Except some training. Couple of days and few batteries behind. Kuva
Rig still feels awesome. I think I've finally found the confidence to drive it like it should be driven.
We have two more comps before this rigs first comp against other supers in the Nordics. I'll do some more batteries, and then I think I'm ready to go against Norway, Sweden and France! Kuva
Re: #2 Bagdaröök
Last training before the first comp of this rigs career.
Week ago in our local comp.
Now I feel I have done "enough" training to reach the good basic performance of this thing.
Still it manages to suprise me on every driving session. Kuva
Going for the tricky bonus. Never made it with any of my rigs. It truely was a tricky one.
Sidehilling is like childs play with 4ws.
Another bonus on the edge.
As you can see from this pic I snapped quite a few pins off from all four tires. The grip became much better. I wasn't sure at first to do so much cutting, but luckily I did. Kuva
Tricky bonus three. This was a pro class course.
It's there. Kuva
https://youtu.be/SA61LQb06_Y
Here is the first course of the morning in video. Pretty pleased how it did the sixth gate. Kuva
On the next day it was time to prepare it for the big comp. New lexan cover for the electronics behind the front axle.
The old shrink has began to wear off.
Ugly as hell, but it covers my electronics at least.
Changed some screws in the chassis, which were too weak to be aluminium. Like front and rear upper link screws. I'll get the set of spacers for my 3D printed hex hubs in Norway. I'll attach them there. Otherwise it's ready for the first battle! Kuva
So are my other rigs. Good feeling to be well prepared early. Kuva
My goal is to fight for the win of course. Eleven rigs registered for the comp, which is really good number of rigs bearing in mind that there was only 17 in the Worlds last year. One finnish, two swedish, two french and six norwegian rigs. It's gonna be a good first comp. Can't wait! Kuva
Re: #2 Bagdaröök
Onnittelut hienosta 2-sijasta!
Harmilliset 6-pinnaa voittajaan ja 4 luokan voittoon.. Noh, jääpähän "nälkää" tulevaisuuteenkin   ;)
Re: #2 Bagdaröök
[quote="Hadesbear"]
Kiitokset! Pettymys kaivertaa kyllä mieltä. Mutta oma moka...
So, first comp behind with this rig and I'm pleased of how it is working.
Course one was the most fun of the day.
I had zero problems with the rig apart from the salty ocean water on my deans plugs. Luckily that was no big deal.
Coming down from gate three.
Smooth, no mistakes so far. Kuva
Gate seven and down we go again.
Going for last two of the gates. Behind you can see the staggering scenery of this comp site! Kuva
Voodoo pins gave me all the traction there is.
Course two was the decider course this time.
Here. I chose little bit wrong line and ended up dipping the whole front tire into the hole. Ten point reposition was the only way to deal with it. KuvaKuva
After that stupid mistake everything went relatively well.
Going for gate six up top.
Used every trick I knew to make the turns without reverse.
There wasn't too much room for turning.
Last two gates ahead!
On the first try I chose the wrong line and almost flipped the whole thing over. Took one reverse to escape it clean.
Time for some video! Kuva
Course 1 - (-20/-20)
https://youtu.be/THLpmE8VL1k
My favorite course all day. Starting from the top of the rock and coming down at first. No bigger issues except gate eight, which I almost forgot. Kuva
Course 2 (-9/-20)
https://youtu.be/DOsA3mG7EfM
This was the course where something did go wrong. Before gate three I got stuck and had to take a reposition. That was too expensive mistake in a three course competition. Kuva Last gate was a tricky one, but after searching the line for more than a minute I found it. Happy about everything else but the repo...
Course 3 - (-10/-20)
https://youtu.be/O6U351VuS6c
This course was basically just walk thru till the very last gate. Gate ten was a vertical cliff, that only one rig passed without bigger problems. I tried to go from the side couple of times, but just couldn't see it going there. Rig was just wide enough to fall from the rock both times. Eventually I just rode the gate over.
Ps. Sorry for all of the salt on the lens. Ocean was a bit rough that day and there was nothing we could do that would help it. Kuva
Eventually I ended up second spot only six points behind the winner Bolt on.
I'm only dissapointed because of my own mistake on that reposition. Otherwise it would've been business as usual. Kuva
You have to get what you deserve, I guess. Kuva
Allthough luckily I didn't go home empty handed. Kuva Thanks for all of the guys who made this weekend possible! Good times! I'm afraid that the next competition for this rig will be in EuroCrawl on november.
Pauli
Re: #2 Bagdaröök
Onneksi ne navat kesti noin isojakin renkaita, vaikka vähän jännittikin että miten käy! :)
Ja hienosti ajettu, vaikka tulikin vähän kämmiä, mutta olishan se ollu kurjaa kaikki luokat voittaa, hä? ;D 8)
Re: #2 Bagdaröök
[quote="Pauli"]
Todella kurjaa...  :P :-X
En missään vaiheessa pelännyt napojen puolesta. Kiinnitys vaikuttaa oikein asialliselta, kun nyt saatiin leveyskin kohdalleen. Uusi napasarja menee tässä syksyn aikana ehdottomasti tilaukseen uuteen projektiin.  ;)
Vs: Bagdaröök
Way too long from the previous update! Kuva
Every now and then I've been driving with this rig.
No faults have been found during the summer. All though, I haven't driven too much with it to be honest. Kuva
These pics are from last comp, where I took it outdoors once more before EuroCrawl! Kuva
Tricky spot. Kuva
Soon it will be time to get set for the big one. More training will happen on the beach rocks of Almuñécar. Kuva
Hedgehog
Vs: Bagdaröök
Viesti Kirjoittaja Hedgehog »
:o Melkoisen HC meininkiä 2.2 luokan huipulla nykyään. Onnea sijoituksesta joka tapauksessa. ????
Vs: Bagdaröök
[quote="Hedgehog"]
Itse asiassa tässä on kyse 4.0 luokasta. Eli superista. HC:ta se kyllä on.  ;D
Vs: Bagdaröök
A little preparation was in place for this rig too.
Opened the axles and saw what's where. Kuva
Everything looks good, so I added VP grease in there. Kuva
Front axle was good as well. I haven't been driving too much with this though. Kuva
Everything set for the second comp with this rig!
Made some stupid mistakes in Norway on June and now it's time to learn from them. Gonna do few days of training before the comp to get "the" feeling. Kuva
https://docs.google.com/spreadsheets/d/ ... lI/pubhtml#
Here you can find live scoring of EuroCrawl 2015. Super will be driven on friday. Kuva
This comp is long waited. There isn't too many super comps in europe and personally I like this class the most. Kuva My goal is  to be European Champion. Kuva But as in shafty, there will be some pretty unforgiving contenders. Fingers crossed! Kuva
Vs: Bagdaröök
Time to sum up the weekend in EuroCrawl.
I arrived at Almuñécar already on sunday.
This was our great hotel during the week. 50m to the rocks. Kuva
We got some training with Arttu, who also had bought a super. Now I can really start training in Finland too! Kuva
Positive feelings in training. Nothing broke and the rig was performing well.
Eating lunch on friday before the super class. Kuva
Doing organisation stuff meant, that I really didn't have any time to "worry" about my performances and competing. I think this was a big key to success. Kuva
Finishing course one. Really long course with tricky gates.
Didn't have time to try the other bonus though. Kuva
Finished! That's good way to begin.
My buddy Fred a.k.a Cirederf asked if he could double start with me in super class. Why not?! It was awesome to see his progress during this one competition already! And it was great to see the rig making twelve courses without bigger problems. Kuva
Going for the bonus on Fanatic RC course.
On this course the rig really showed it's best side. Really easy to handle on these rocks. Only thing I noticed, that I might need smoother motors for this kind of grip. Or smaller pinions. Kuva
Here is the third course. "Norwegian revenge!" Kuva
This side up. Kuva
It was the worst course for me in the whole competition all classes included. -10 points only. Kuva But hell, it was really hard.
Crawler Keller course on the way. I was the only one to finish this. Kuva
Really cool gate with super.
Gate four in progress. The course was really close to the cliff, so driver had to be extra cautious.
Not choosing the obvious line for fifth gate.
All or nothing! Kuva Going for the bonus.
My christmas came early. You see the fishing wire in the front axle? That didn't have any effect on this performance, thank god. Kuva
With this kind of hurry, I didn't find the right line for this gate. Kuva
Rig posing in the sun before the fifth course.
Now a long waited section! Video corner. Kuva
Krawler Konceptz Course (-19/-40)
https://www.youtube.com/watch?v=Nq4Gi5T3QPs
First course since Nordics. Don't know what happened on the very first gate, where I hit a marker. Just a little change in the terrain and whole rig moved few inches. Kuva I knew I had to be quick on this course, cause the distance between first and last gate was guite big. Didn't have time to drive the other bonus, but I'm relatively happy with this score as well. Only bummer was the first gate.
Fanatic RC Course (-40/-40)
https://www.youtube.com/watch?v=5GnKkpdq-GU
I was one of the guys to build this course. I managed to throw in some serious lines and good gates. It was really fun to drive this. Allthough a little excitement on the seventh gate, when the rig rolled into a hole. Recovery of the century came right after that. Kuva Really loved this course! Kuva
Holmes Hobbies Course (-10/-40)
https://www.youtube.com/watch?v=VeXxDr_Rl3I
Then it was time for the trickiest course of the weekend. (At least for me) First gate was easy downhill, but gates 2 to 4 were really tough time killers. Gate two was familiar from the Nordics. I call it "Brumle edition". Kuva No hard feelings Asle. This time it made no exception and I had to take the gate. Third gate was something spectacular as well. My plan almost worked out, until I bounced back on the gate again. Darn! Kuva To gate four I had to find line for a long time. Luckily I had just enough ground clearance to make it from the easy line. Rushed off the rest of the course with one bonus and made it thirteen seconds before the bell rang. Kuva Challenging, but extremely fun course!
Crawler Keller Course (-19/-40)
https://www.youtube.com/watch?v=r8D9bqL7Fbs
In this course we had bit of problems with the camera. Battery died before the first gate and Sofi tried to turn it on again few times and managed to shoot few moments of the course. Too bad, cause this was one performance to remeber! Kuva Right after first gate some fishing wire got round of my tire and axle. Fortunately it didn't have any effect on my performance. Kuva I drove both of the bonuses, which were relatively easy, but relly close to the sea. At gate eight, I had wrong line approaching it, but didn't have enough time to fix it so I hit a marker. Tried gate nine several times from the bottom, but after hearing that there's fourty seconds left went to the top to straddle it. Managed to clear gate ten with five seconds remaining. No wonder nobody else made it through. Kuva
Team Ottsix Course (-18/-40)
https://www.youtube.com/watch?v=-5UKVNMCFvI
Another course made by me. This time it didn't go as well as in Fanatic RC course. First three gates, no problem. At fourth gate, I wasn't able to climb on top of the cliff to hang my tire and climb up. Tried the line from the side, but rig got in bad position and I had to take the marker. This was a tough gate with all honesty. At eight gate my approach was poor and I dropped off from the cliff. Drove the other bonus and straddled the gate to make it in time. Few stupid mistakes, but no bigger harm done. Just need to practise more how the rig is reacting in sidehills. Kuva
RcBros Course (-30/-40)
https://www.youtube.com/watch?v=uxI4mzKfpqY
Last course for me of EuroCrawl 2015. Wanted badly to make good performance here. Kuva Everything went well up untill the fourth gate. I was already through the gate when the rig bounced back on it. Kuva This is purely one of those reactions of the rig, that I know only by driving with it more. Stupid, stupid, stupid. Kuva Rest of the course went really well though, so this didn't feel too bad after all. Tasting the champagne at the end, was really perfect end to a perfect opening day of EuroCrawl! Kuva
Prize giving to top three of Super and 1.9 classes.
Happy to take the win for DravTech Super SuDu!! Kuva
Big congrats to Arttu, who came second in his debut comp with supers. I can already see some pontential with training together! Kuva Congrats to David cathcing the third as well! Nice driving! Kuva
Previously unseen in the crawling competitions! Champagne!! KuvaKuva
Here are the results. Ok, slight gap. I have to be proud of that! Kuva
This was important step in my path. I still think super is the class of kings. Kuva
All in all, I had great time in Spain! Kuva
Big thanks to the supporters of the competition! Raffle prizes were really cool this year! Huge thanks to DravTech being the title sponsor. Kuva
We went on top of Almuñécar at the morning of departure. This scenery is really one of a kind. Kuva It really was great weekend and trip to the south. All of the guys who came there made it perfect. Big thanks to all of my friends! Another thank of this year goes to my current and previous sponsors/supporters:
DravTech
RC4WD
Team Ottsix
PURPMART
Krawler Konceptz
Offipaita.fi
Team Brood Racing
E.Y. Designs
It's good to continue from this in next year. Bagdaröök will be back. Even stronger. Kuva
