Kai-modosu
2.2s (shafty)
Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Su 30.11.2014 16:46
買い戻す
"Until my hearth is cold, every breath of mine is yours"
Kai-modosu - European Champion 2015
Kai-modosu - Finnish Champion 2015
Kai-modosu - Nordic Champion 2015
Tekniikka:
Akselit: RC4WD Bully 2"-S" Modded by Sendai Mokei RC Crawlers
Runko: DravTech NCD SuDu Pro
Linkit: Dlux titanium
Moottori: Team Brood Racing Nexus 35T HHK-T Regular
Nopari: Castle Creations Micro Sidewinder
Bec: Castle Creations 10A
Servo: Futaba BLS157HV
Akut: Gens Ace 450mAh 25-50C 3S LiPo
Renkaat: E.Y. Designs Narrowed Ottsix Voodoos (Narrow golds front and ultra narrow silvers rear)
Vanteet: Dlux Solid Face CF (0.87" front and 0.72" rear)
Foamit: Crawler Innovations Double Deuce (5.5" front and 6.0" rear)
Iskarit: Axial SCX10 Aluminium
Jouset: Front: Team Losi Mini Rock Crawler (Silver) Rear: Team Losi Mini-T Rear (Blue)
Kori: Parma XCitier (Tarrat: Krawler Konceptz)
Radiot: Sanwa MT-4
Muuta:
- Dlux knucklet ja dlux vetarit
Tulokset matkan varrelta:
2015:
EuroCrawl (European Championships) Almuñécar, Espanja: 1
Nordics (Nordic Championships) Tjøme, Norja: 1
Finnish RC Crawling Series #1, Kuopio: 1
Finnish RC Crawling Series #2, Kirkkonummi: 1
Finnish RC Crawling Series #3, Nokia: 1
Finnish RC Crawling Series #4, Kotka: 1
Finnish RC Crawling Series #5, Rauma: 1
RFOT's Crawl Cup #2/12, Lahti Bunker: 1
RFOT's Crawl Cup #3/12, Karhusuo: 1
RFOT's Crawl Cup #4/12, Nokian Kivilaakso: 1
RFOT's Crawl Cup #5/12, Rauma: 1
RFOT's Crawl Cup #6/12, Keljonkangas: 1
RFOT's Crawl Cup #7/12, Inkoo: 1
RFOT's Crawl Cup #8/12, Naantali: 1
RFOT's Crawl Cup #9/12, Lappeenranta: 1
RFOT's Crawl Cup #10/12, Lahti: 1
RFOT's Crawl Cup #11/12, Koukkujärvi:
1
RFOT's Crawl Cup #12/12, Pirkkala:
1
Finnish RC Crawling Series 2015:
1
RFOT's Crawl Cup 2015: 1
Kisoja takana:
18
#1: 18
Viimeksi muokannut Zarizi Tech, Ti 22.12.2015 11:20. Yhteensä muokattu 1 kertaa.
Re: #4 Kai-modosu
Viesti Kirjoittaja Pasi » Su 30.11.2014 19:05
Heeetkonen.... Bully akselinen shafty   :o Kuvia odotellessa.
Re: #4 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Su 30.11.2014 19:24
[quote="Pasi"]
Akselit vielä Japanissa. Kuvia tulee kun saan ne käsiini.  ;)
Re: #4 Kai-modosu
Viesti Kirjoittaja Hadesbear » Su 30.11.2014 19:57
Pasi kirjoitti: Heeetkonen.... Bully akselinen shafty   :o Kuvia odotellessa.
Se on sitä "tulevaisuutta", ämmämeis oli se yks... joka sattumalta oli se yks... joka voitti   ;D
Tuosta on tuleva uusi buumi ja nyky 2.2s autoilla ei tee enää mitää..   ;D
Re: #4 Kai-modosu
Viesti Kirjoittaja Tomy » Su 30.11.2014 20:27
Nerokas idea!
Mutta se on sitten taas hei hei edulliselle ja aloittelijaystävälliselle crawling-luokalle. Juuri tämä ilmiö tappaa crawlingin, kun ei löydy kaupasta mitään 300 eurolla, jolla voi kilpailla. Innovaatiot crawlingissa ovat kyllä huimia, sitä ei käy kieltäminen.
Re: #4 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Su 30.11.2014 20:41
[quote="Tomy"]
Nerokas idea!
Se on kyllä sääli. Mutta koitetaan joku täältä pohjolastakin pysyä aallonharjalla...
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Ti 02.12.2014 20:56
Nyt alko tapahtumaan!  ;)
Let's start with the front axle which will require some dremeling.
On the other side.
The front gearbox before added parts.
Step by step.
New gear.
Assembling the mount for shaft output.
This is how it looks assembled.
I'm gonna give you as many angles as I can.
Motor will be attached to the original place.
Mount from the other side.
Next step attaching the shaft output.
Last pic of the adapter.
Shaft adapter to front axle! Kuva
Mounted.
From the shaft end.
I will use the old axles from my Pro on this. Kuva
Finished product. Kuva
SMRC Crawlers from Japan offered me Bully 2-S version for testing. This is just prototype version. Rear axle unit is similiar to the one in front, but it will just replace the motor unlike this in front.
I'm thrilled to see how this thing will perform. But to test it, I need to build it first. Now I'm waiting for the parts starting to roll to the north. Kuva This is a good start though!
Will keep you guys posted. I'm sure everyone is interested how these are made, so now you have the chance to look behind the secret japanese curtain. Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja LaaLaa » Ti 02.12.2014 22:22
Mitkä rattaat kulmavaihteessa?
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Ke 03.12.2014 18:21
[quote="LaaLaa"]
Laitoin kyselyä.
macman
Re: #6 Kai-modosu
Viesti Kirjoittaja macman » La 06.12.2014 00:14
Ääh mää luulin että tosta tehdään hihnavetoinen   4-veto   mikä pettymys   ;D
Touring auton takahubille on löytynyt näköjään uusii käyttöä   :o
RaumRC
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Su 07.12.2014 14:43
[quote="macman"]
Voithan sinä itse tehdä sen hihnavedon, jos idea on?  ;D Jep, nyt purat sen turistin ja keksit sille parempaa käyttöä.  ;)
Conversion kit is ready in Japan and now heading my way. Can't wait to start building! All except tires are on the way to me. Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Ke 10.12.2014 16:49
Today I got some time to look out what I have for this project already.
Received bunch of batteries. Kuva Kuva
And the chassis from DravTech! Kuva
Screwed it together with al hardware.
It looks different without the cabin. Kuva
This is what I have + the receiver.
Rear axle has to be cleaned and prepared before action.
Something is missing between the tubes? Hoping it'll come quickly! Kuva Whoops, my pro knuckles and knuckleweights won't be part of this rig. I forgot them on.
Tomorrow I will receive the XCitier body from Crawler Innovations.
And within few days packages from Krawler Konceptz, Dlux and SMRC Crawlers. Kuva I'll wait to get all the parts here and then start building. I have few other projects in the mean time as you might have noticed. Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Ma 15.12.2014 16:28
Some stuff for my 2.2 rigs! Kuva
Got a free Cell Block! Thanks Eddie! KuvaKuva
And the XCitier body. Gotta save some of that lexan for covering the front and rear gears somehow. Kuva
Tomorrow I'll get the rest of the transmission parts from Japan! I'll keep you guys well posted on them! Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » To 18.12.2014 21:12
Anyways, parts arrived from Japan today. Finnish post screwed the delivery badly and it came over eight days late... Kuva But I'm still happy that it's not lost. Kuva
Goodies from Nippon! Kuva A big thanks to Sendai Mokei RC Crawlers! Kuva
As excited as a little child. Again! Kuva
Some information of gear ratios and the building. Kuva
Much smaller and lighter what I thought. Kuva
This bit goes to the chassis. It was ridicilously light! Kuva
Front axle housing and the modification.
Really pleased with the parts. Top notch finish in all of them. Kuva
Still waiting one more package from Dlux to start the building. It should arrive tomorrow. Can't wait to start! Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Ma 22.12.2014 20:58
I finally received the next pack of goodies from Dlux! Kuva
Quick shipping! Kuva
All those goodies! My christmas is early this year! Kuva
Most of these stuff were for my shafty.
Here are all of the stuff gathered together.
Hmmmm... Can't decide what to do first! Kuva
Maybe first I have to remove those Bully knuckles and knuckleweights, cause I wont be using them.
After that I could build these. Kuva
Here are the beefy shafths for my front axle. I'll have to shave them down quite a bit, cause right now, they won't fit in Bully 2 tube... Kuva
Ordered the knuckles with slugs and that seemed to be a good call. They are plenty heavy enough already without them. About 90 grams a piece. Kuva
Some head shrcatching... Hmm, they probably have to be another way around... Kuva
Now I got the other knuckle right, and still managed to mess up with the other. Kuva I'll have to shave down my hubs as well to make it a perfect match.
Next up - the links.
Rear links assembled. That bending looks quite extreme for shafty. I might have to do something about it...
Front and rear lowers assembled to the chassis! Kuva
Next up some weight readings of my transmission parts. This is the middle part which goes to chassis.
And this is my rear axles transmission.
Next would be checking the rear axle and building both of the axles. All the gears and bearings were in flawless condition after one season with  my pro. Won't need changing yet. Kuva
New grease to the rear axle and it's ready to go again. Kuva At this point the battery of my camera died and I wasn't able to shoot pics from the axle building.
Then I had to go to market to get some new batteries for it, and here are the finished products. This is now the complete rear axle.
And here is front axle. Kuva Everything did go there without a problem.
Here is where I'm at now. As you can see from this pic the upper links will be really tricky ones to make work. And there is still a lot of unanswered questions of this build.
It won't be an easy one to build, but I really wasn't expecting so. Kuva Fact is at the moment, it probably wont be finished to our first comp on 10th of January... Now I need to get my pro going first. Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Pe 26.12.2014 21:45
Continued a little today.
Shaving the hubs to make a perfect match with Dlux knuckles.
Had to shave about that much on both sides.
Easy job. Kuva
Next thing will be to drill the tubes for them shafts. Kuva
It'll look something like never before! Kuva
With Dlux shaft shaving, this thing will turn! Kuva
Really started to think about changing these to my other rigs as well. Amazing product! Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » La 03.01.2015 17:30
After I finished my pro, I got a little time today to do the shocks for my shafty.
Axial SCX10 aluminium shocks. Losi Mini-T rear springs in the rear and Losi Mini Crawler soft springs in front.
And Dlux no-preload mini-t cups.
For the moment I'll try with the same spring setup, that my pro has.
Got no more time today, but I'll continue tomorrow with the decals of the body. Kuva I heard that Michelle is waiting to see them. Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja Hadesbear » La 03.01.2015 20:43
Hyvinhän se etenee, kun ottaa huomioon sen seikan, että on jotain aivan toisenlaista ylipäänsä rakentaa!
Mielenkiintoista seurata vierestä tämän edistymistä. Ottanee aikansa, mutta kun on "tikissä", niin tämä tulee olemaan brutaali
Re: #6 Kai-modosu
Viesti Kirjoittaja Zarizi Tech » Su 04.01.2015 18:41
[quote="Hadesbear"]
Joo, kyllä koko ajan saa päätä rapsuttaa, että mites nääkin osat yhdistetään. Pikkuhiljaa hermoja (pahasti) menettämättä eteenpäin. Eka kisa ens viikonloppuna näyttää kuitenkin jäävän haaveeksi.
Progress.....!
Let's start prepping the body!
First cutting of the lexan from around the body.
That's what I have left. I'll be using those to cover the gears in the axles. Kuva
Decals are on it. A slight blue'ish shade over it, cause of the protective film.
Looking awesome! Kuva
Now I just have start to think wheter to paint it with red or black?
That'll look way too cool! Kuva
The gold stands for it's own there. Kuva
Window covers are on and I shall get to the painting tomorrow! Kuva
Re: #6 Kai-modosu
Viesti Kirjoittaja SlidSlide » Ma 05.01.2015 11:38
Kyllä näissä Samun autoissa on upeat kopat. Mitäänsanomattomasta koristakin tulee komea, kun vähän panostaa skinzeihin 8).
"Viiden pennin filosofi"
